Book sections
Multimodal Image Registration and Visual Servoing
Abstract : This paper deals with multimodal imaging in the surgical robotics context. 1 On the first hand, it addresses numerical registration of a preoperative image obtained 2 by fluorescence with an intraoperative image grabbed by a conventional white-light 3 endoscope. This registration involves displacement and rotation in the image plane as 4 well as a scale factor. On the second hand, a method is developed to visually servo the 5 endoscope to the preoperative imaging location. Both methods are original and dually 6 based on the use of mutual information between a pair of fluorescence and white-light 7 images and of a modified Nelder-Mead simplex algorithm. Numerical registration is 8 validated on real images whereas visual servoing is validated experimentally in two 9 setups: a planar microrobotic platform and a 6DOF parallel robot.
Document type :
Book sections
Complete list of metadata
Cited literature [13 references]  Display  Hide  Download
https://hal.inria.fr/hal-01433996
Contributor : Eric Marchand Connect in order to contact the contributor
Submitted on : Friday, January 13, 2017 - 10:26:27 AM
Last modification on : Friday, January 21, 2022 - 3:09:02 AM
Long-term archiving on: : Friday, April 14, 2017 - 5:01:02 PM
File
book_chapter_3.pdf
Identifiers
Citation
Mouloud Ourak, Brahim Tamadazte, Nicolas Andreff, Eric Marchand. Multimodal Image Registration and Visual Servoing. Lecture Notes in Electrical Engineering, 383, Springer, pp.157 - 175, 2016, ⟨10.1007/978-3-319-31898-1_9⟩. ⟨hal-01433996⟩
Share
Metrics
Record views
540
Files downloads
131
