Multithreading-enabled active replication for event stream processing operators. SRDS, Niagara Falls, 2009. ,
DOI : 10.1109/srds.2009.37
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.158.1573
Integrating scale out and fault tolerance in stream processing using operator state management, 2013. ,
Computer and job-shop scheduling theory, 1976. ,
Elastic scaling for data stream processing. Parallel and Distributed Systems, IEEE Transactions on, vol.25, issue.6, pp.1447-1463, 2014. ,
DOI : 10.1109/tpds.2013.295
URL : http://repository.bilkent.edu.tr/bitstream/11693/12708/1/8297.pdf
Streamcloud: An elastic and scalable data streaming system. Parallel and Distributed Systems, IEEE Transactions on, vol.23, issue.12, pp.2351-2365, 2012. ,
DOI : 10.1109/tpds.2012.24
URL : https://hal.archives-ouvertes.fr/lirmm-00748992
Latency-aware elastic scaling for distributed data stream processing systems, Proceedings of the 8th ACM International Conference on Distributed Event-Based Systems, DEBS '14, 2014. ,
DOI : 10.1145/2611286.2611294
An adaptive replication scheme for elastic data stream processing systems, Proceedings of the 9th ACM International Conference on Distributed Event-Based Systems, DEBS '15, 2015. ,
DOI : 10.1145/2675743.2771831
A multi-resource load balancing algorithm for cloud cache systems, Proceedings of the 28th Annual ACM Symposium on Applied Computing, SAC '13, 2013. ,
DOI : 10.1145/2480362.2480453
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.697.1522
Scalable distributed event detection for Twitter, 2013 IEEE International Conference on Big Data, 2013. ,
DOI : 10.1109/BigData.2013.6691620
The power of both choices: Practical load balancing for distributed stream processing engines, 2015 IEEE 31st International Conference on Data Engineering, 2015. ,
DOI : 10.1109/ICDE.2015.7113279
Streaming first story detection with application to twitter. Human Language Technologies, The 2010 Annual Conference of the North American Chapter of the Association for Computational Linguistics, pp.181-189, 2010. ,
Efficient key grouping for near-optimal load balancing in stream processing systems, Proceedings of the 9th ACM International Conference on Distributed Event-Based Systems, DEBS '15, 2015. ,
DOI : 10.1145/2675743.2771827
URL : https://hal.archives-ouvertes.fr/hal-01194518
Staying fit: Efficient load shedding techniques for distributed stream processing, 2007. ,
Elastic complex event processing exploiting prediction, 2015 IEEE International Conference on Big Data (Big Data), 2015. ,
DOI : 10.1109/BigData.2015.7363758
Insights on a Scalable and Dynamic Traffic Management System, 2015. ,
