Abstract : In this paper, we present PAN, a generic middleware for distributed real-time complex event detection (CED) which is able to analyze multiple distributed data streams. In PAN, CED applications are defined as workflows and are executed by dedicated workers in a distributed way in a P2P network. In consequence, PAN is scalable in terms of the number of data streams and the complexity of the analyses. Evaluations based on an extended version of the ACM DEBS 2013 Grand Challenge scenario show the effectiveness and efficiency of PAN.
https://hal.inria.fr/hal-01434794 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, January 13, 2017 - 2:02:32 PM Last modification on : Friday, January 13, 2017 - 2:05:49 PM Long-term archiving on: : Friday, April 14, 2017 - 8:37:12 PM
Lukas Probst, Ivan Giangreco, Heiko Schuldt. PAN – Distributed Real-Time Complex Event Detection in Multiple Data Streams. 16th IFIP WG 6.1 International Conference on Distributed Applications and Interoperable Systems (DAIS), Jun 2016, Heraklion, Crete, Greece. pp.189-195, ⟨10.1007/978-3-319-39577-7_15⟩. ⟨hal-01434794⟩
