Abstract : The migration of network functions (NFs) to datacenters, as promoted by Network Function Virtualization (NFV), raises the need for service chaining (i.e., steering traffic through a sequence of NFs). Service chaining is typically performed by installing forwarding entries in switches within datacenters (DCs). However, as the number of service chains in DCs grows, switches will be required to maintain a large amount of forwarding state. This will raise a dataplane scalability issue, due to the relatively small flow table size of switches. To mitigate this problem, we present a software-defined network (SDN) based source routing architecture for scalable service chaining, at which the NF-path is encoded into the packet header obviating the need for any forwarding state and lookup in the switches. We assess the feasibility and efficiency of our architecture using a prototype implementation.
Type de document :
Communication dans un congrès
Lefteris Mamatas; Panagiotis Papadimitriou; Ibrahim Matta; Yevgeni Koucheryavy. 14th International Conference on Wired/Wireless Internet Communication (WWIC), May 2016, Thessaloniki, Greece. Lecture Notes in Computer Science, LNCS-9674, pp.66-77, 2016, Wired/Wireless Internet Communications. 〈10.1007/978-3-319-33936-8_6〉
https://hal.inria.fr/hal-01434868
Contributeur : Hal Ifip
Soumis le : vendredi 13 janvier 2017 - 14:35:09
Dernière modification le : vendredi 13 janvier 2017 - 14:45:31
Document(s) archivé(s) le : vendredi 14 avril 2017 - 19:38:02
Ahmed Abujoda, Hadi Kouchaksaraei, Panagiotis Papadimitriou. SDN-Based Source Routing for Scalable Service Chaining in Datacenters. Lefteris Mamatas; Panagiotis Papadimitriou; Ibrahim Matta; Yevgeni Koucheryavy. 14th International Conference on Wired/Wireless Internet Communication (WWIC), May 2016, Thessaloniki, Greece. Lecture Notes in Computer Science, LNCS-9674, pp.66-77, 2016, Wired/Wireless Internet Communications. 〈10.1007/978-3-319-33936-8_6〉. 〈hal-01434868〉
