An 8-State Simple Reversible Triangular Cellular Automaton that Exhibits Complex Behavior - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Kenichi Morita
  • Fonction : Auteur
  • PersonId : 998306
A three-neighbor triangular partitioned cellular automaton (TPCA) is a CA whose cell is triangular-shaped and divided into three parts. The next state of a cell is determined by the three adjacent parts of its neighbor cells. The framework of TPCA makes it easy to design reversible triangular CAs. Among them, isotropic 8-state (i.e., each part has two states) TPCAs, which are called elementary TPCAs (ETPCAs), are extremely simple, since each of their local transition functions is described by only four local rules. In this paper, we investigate a specific reversible ETPCA T 0347 , where 0347 is its identification number in the class of 256 ETPCAs. In spite of the simplicity of the local function and the constraint of reversibility, evolutions of configurations in T 0347 have very rich varieties, and look like those in the Game-of-Life CA to some extent. In particular, a “glider” and “glider guns” exist in T 0347 . Furthermore, using gliders to represent signals, we can implement universal reversible logic gates in it. By this, computational universality of T 0347 is derived.
395687_1_En_14_Chapter.pdf (242.53 Ko) Télécharger le fichier
hal-01435027 , version 1 (13-01-2017)
Paternité
Kenichi Morita. An 8-State Simple Reversible Triangular Cellular Automaton that Exhibits Complex Behavior. 22th International Workshop on Cellular Automata and Discrete Complex Systems (AUTOMATA), Jun 2016, Zurich, Switzerland. pp.170-184, ⟨10.1007/978-3-319-39300-1_14⟩. ⟨hal-01435027⟩
74 Consultations
102 Téléchargements
