A ranking of diffusion MRI compartment models with in vivo human brain data, Magnetic Resonance in Medicine, vol.49, issue.6, pp.1785-1792, 2014. ,
DOI : 10.1002/mrm.25080
NODDI: Practical in vivo neurite orientation dispersion and density imaging of the human brain, NeuroImage, vol.61, issue.4, pp.1000-1016, 2012. ,
DOI : 10.1016/j.neuroimage.2012.03.072
A new multi-fiber model for low angular resolution diffusion MRI, 2012 9th IEEE International Symposium on Biomedical Imaging (ISBI), pp.936-939, 2012. ,
DOI : 10.1109/ISBI.2012.6235710
URL : https://hal.archives-ouvertes.fr/inserm-00858205
A Mathematical Framework for the Registration and Analysis of Multi-Fascicle Models for Population Studies of the Brain Microstructure, IEEE Transactions on Medical Imaging, vol.33, issue.2, pp.504-521, 2014. ,
DOI : 10.1109/TMI.2013.2289381
URL : https://hal.archives-ouvertes.fr/inserm-00903679
Diffusion MRI: From quantitative measurement to in-vivo neuroanatomy, 2009. ,
Functional magnetic resonance imaging, 2004. ,
Correction for geometric distortion in echo planar images from B0 field variations, Magnetic Resonance in Medicine, vol.29, issue.1, pp.65-73, 1995. ,
DOI : 10.1002/mrm.1910340111
Correction of off resonance-related distortion in echo-planar imaging using EPI-based field maps, Magnetic Resonance in Medicine, vol.28, issue.2, pp.328-330, 1998. ,
DOI : 10.1002/mrm.1910390223
Efficient correction of inhomogeneous static magnetic field-induced distortion in Echo Planar Imaging, NeuroImage, vol.50, issue.1, pp.175-183, 2010. ,
DOI : 10.1016/j.neuroimage.2009.11.044
Comparison of EPI Distortion Correction Methods in Diffusion Tensor MRI Using a Novel Framework, MICCAI, Part II, ser. LNCS, pp.321-329, 2008. ,
DOI : 10.1007/978-3-540-85990-1_39
Measurement of the point spread function in MRI using constant time imaging, Magnetic Resonance in Medicine, vol.5, issue.5, pp.733-740, 1997. ,
DOI : 10.1002/mrm.1910380509
An improved PSF mapping method for EPI distortion correction in human brain at ultra high field (7T), Magnetic Resonance Materials in Physics, Biology and Medicine, vol.20, issue.1, pp.179-190, 2011. ,
DOI : 10.1007/s10334-011-0251-1
Point spread function mapping with parallel imaging techniques and high acceleration factors: Fast, robust, and flexible method for echo-planar imaging distortion correction, Magnetic Resonance in Medicine, vol.48, issue.5, pp.1156-1166, 2004. ,
DOI : 10.1002/mrm.20261
A technique for accurate magnetic resonance imaging in the presence of field inhomogeneities, Soc. Magn. Res. Abstr, pp.319-329, 1992. ,
DOI : 10.1109/42.158935
How to correct susceptibility distortions in spin-echo echo-planar images: application to diffusion tensor imaging, NeuroImage, vol.20, issue.2, pp.870-888, 2003. ,
DOI : 10.1016/S1053-8119(03)00336-7
Fiber tracking in the cervical spine and inferior brain regions with reversed gradient diffusion tensor imaging, Magnetic Resonance Imaging, vol.24, issue.3, pp.231-239, 2006. ,
DOI : 10.1016/j.mri.2005.12.007
Correction of spatial distortion in EPI due to inhomogeneous static magnetic fields using the reversed gradient method, Journal of Magnetic Resonance Imaging, vol.39, issue.4, pp.499-507, 2004. ,
DOI : 10.1002/jmri.20032
Single-shot compensation of image distortions and BOLD contrast optimization using multi-echo EPI for real-time fMRI, NeuroImage, vol.24, issue.4, pp.1068-1079, 2005. ,
DOI : 10.1016/j.neuroimage.2004.10.012
Distortion Correction in EPI Using an Extended PSF Method with a Reversed Phase Gradient Approach, PLOS ONE, vol.6, issue.2, 2015. ,
DOI : 10.1371/journal.pone.0116320.g008
DR-BUDDI (Diffeomorphic Registration for Blip-Up blip-Down Diffusion Imaging) method for correcting echo planar imaging distortions, NeuroImage, vol.106, pp.284-299, 2015. ,
DOI : 10.1016/j.neuroimage.2014.11.042
A Review of Methods for Correction of Intensity Inhomogeneity in MRI, IEEE Transactions on Medical Imaging, vol.26, issue.3, pp.405-421, 2007. ,
DOI : 10.1109/TMI.2006.891486
Block Matching: A??General??Framework??to??Improve Robustness of??Rigid??Registration of Medical Images, Medical Image Computing and Computer-Assisted Intervention?MICCAI, pp.557-566, 2000. ,
DOI : 10.1007/978-3-540-40899-4_57
URL : https://hal.archives-ouvertes.fr/inria-00615860
Automated Diffeomorphic Registration of Anatomical Structures with Rigid Parts: Application to Dynamic Cervical MRI, Medical Image Computing and Computer-Assisted Intervention?MICCAI 2012, pp.163-170, 2012. ,
DOI : 10.1007/978-3-642-33418-4_21
URL : https://hal.archives-ouvertes.fr/inserm-00716106
Blockmatching strategies for rigid registration of multimodal medical images, 2012 9th IEEE International Symposium on Biomedical Imaging (ISBI, pp.700-703, 2012. ,
URL : https://hal.archives-ouvertes.fr/inserm-00681610
Symmetric diffeomorphic image registration with cross-correlation: Evaluating automated labeling of elderly and neurodegenerative brain, Medical Image Analysis, vol.12, issue.1, pp.26-41, 2008. ,
DOI : 10.1016/j.media.2007.06.004
The Laplacian Pyramid as a Compact Image Code, IEEE Transactions on Communications, vol.31, issue.4, pp.532-540, 1983. ,
DOI : 10.1109/TCOM.1983.1095851
The BOBYQA algorithm for bound constrained optimization without derivatives, Centre for Mathematical Sciences, 2009. ,
Processing and visualization for diffusion tensor MRI, Medical Image Analysis, vol.6, issue.2, pp.93-108, 2002. ,
DOI : 10.1016/S1361-8415(02)00053-1
A Fast and Log-Euclidean Polyaffine Framework for Locally Linear Registration, Journal of Mathematical Imaging and Vision, vol.8, issue.3, pp.222-238, 2009. ,
DOI : 10.1007/s10851-008-0135-9
URL : https://hal.archives-ouvertes.fr/inria-00616084
Symmetric Log-Domain Diffeomorphic Registration: A Demons-Based Approach, Lecture Notes in Computer Science, vol.5241, pp.754-761, 2008. ,
DOI : 10.1007/978-3-540-85988-8_90
URL : https://hal.archives-ouvertes.fr/inria-00280602
Cardinal spline interpolation, ser. Regional conference series in applied mathematics, 1973. ,
DOI : 10.1137/1.9781611970555
PROPELLER EPI: An MRI technique suitable for diffusion tensor imaging at high field strength with reduced geometric distortions, Magnetic Resonance in Medicine, vol.52, issue.5, pp.1232-1240, 2005. ,
DOI : 10.1002/mrm.20677
