CoReach: Cooperative Gestures for Data Manipulation on Wall-sized Displays - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Multi-touch wall-sized displays afford collaborative exploration of large datasets and reorganization of digital content. However, standard touch interactions, such as dragging to move content, do not scale well to large surfaces and were not designed to support collaboration, such as passing an object around. This paper introduces CoReach, a set of collabora-tive gestures that combine input from multiple users in order to manipulate content, facilitate data exchange and support communication. We conducted an observational study to inform the design of CoReach, and a controlled study showing that it reduced physical fatigue and facilitated collaboration when compared with traditional multi-touch gestures. A final study assessed the value of also allowing input through a handheld tablet to manipulate content from a distance.
CHI17-coreach-halv1.pdf (4.78 Mo) Télécharger le fichier
CHI17-coreach.mp4 (27.89 Mo) Télécharger le fichier
Format : Figure, Image
hal-01437091 , version 1 (17-01-2017)
Can Liu, Olivier Chapuis, Michel Beaudouin-Lafon, Eric Lecolinet. CoReach: Cooperative Gestures for Data Manipulation on Wall-sized Displays. Proceedings of the 35th international conference on Human factors in computing systems, May 2017, Denver, United States. ⟨10.1145/3025453.3025594⟩. ⟨hal-01437091⟩
1388 Consultations
651 Téléchargements
