Generating higher order quantum dissipation from lower order parametric processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Quantum Science and Technology Année : 2017
Stabilization of quantum manifolds is at the heart of error-protected quantum information storage and manipulation. Nonlinear driven-dissipative processes achieve such stabilization in a hardware efficient manner. Josephson circuits with parametric pump drives implement these nonlinear interactions. In this article, we propose a scheme to engineer a four-photon drive and dissipation on a harmonic oscillator by cascading experimentally demonstrated two-photon processes. This would stabilize a four-dimensional degenerate manifold in a superconducting resonator. We analyze the performance of the scheme using numerical simulations of a realizable system with experimentally achievable parameters.
1612.04341.pdf (1.73 Mo) Télécharger le fichier
hal-01437303 , version 1 (20-09-2023)
Shantanu O. Mundhada, Alexander Grimm, Steven Touzard, Uri Vool, Shyam Shankar, et al.. Generating higher order quantum dissipation from lower order parametric processes. Quantum Science and Technology, 2017, ⟨10.1088/2058-9565/aa6e9d⟩. ⟨hal-01437303⟩
151 Consultations
5 Téléchargements
