Abstract : A performance analysis of a synchronous reluctance motor (SynRM) drive, operating under different fault conditions, with a three-level NPC inverter, controlled by a seven-segment Space Vector Modulation (SVM) technique, is presented in this paper. Considering the voltage source inverter, open-circuit faults of different types are introduced and their effects are studied regarding the SynRM and the inverter performance evaluation. The healthy and faulty operating conditions comparison will take into account the evaluation of some variables, such as the motor power factor, electromagnetic torque, efficiency, total waveform distortion values, currents RMS values, and total waveform oscillation values, obtained from simulation results.
https://hal.inria.fr/hal-01438246 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, January 17, 2017 - 3:37:51 PM Last modification on : Tuesday, January 17, 2017 - 3:49:45 PM Long-term archiving on: : Tuesday, April 18, 2017 - 2:58:47 PM
Diogo Matos, Jorge Estima, Antonio Cardoso. Fault Analysis of Three-Level NPC Inverters in Synchronous Reluctance Motor Drives. 7th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Apr 2016, Costa de Caparica, Portugal. pp.206-216, ⟨10.1007/978-3-319-31165-4_21⟩. ⟨hal-01438246⟩
