Synchronous Reluctance Machines-A Viable Alternative for AC Drives?, Electric Machines and Power Systems, pp.659-671, 1991. ,
DOI : 10.1109/28.54247
Modeling synchronous reluctance motors including saturation, iron losses and mechanical losses, 2014 International Symposium on Power Electronics, Electrical Drives, Automation and Motion, pp.595-600, 2014. ,
DOI : 10.1109/SPEEDAM.2014.6871965
Modeling and Implementation of MTPA Control Strategy for SynRM Variable Speed Drives, International Review of Electrical Engineering (IREE), vol.9, issue.6, 2014. ,
DOI : 10.15866/iree.v9i6.4357
Performance evaluation of synchronous reluctance motor drives under inverter fault conditions, 2015 IEEE 10th International Symposium on Diagnostics for Electrical Machines, Power Electronics and Drives (SDEMPED), 2015. ,
DOI : 10.1109/DEMPED.2015.7303728
The age of multilevel converters arrives, IEEE Industrial Electronics Magazine, vol.2, issue.2, pp.28-39, 2008. ,
DOI : 10.1109/MIE.2008.923519
A Survey on Neutral-Point-Clamped Inverters, IEEE Transactions on Industrial Electronics, vol.57, issue.7, pp.2219-2230, 2010. ,
DOI : 10.1109/TIE.2009.2032430
Medium-Voltage Multilevel Converters—State of the Art, Challenges, and Requirements in Industrial Applications, IEEE Transactions on Industrial Electronics, vol.57, issue.8, pp.2581-2596, 2010. ,
DOI : 10.1109/TIE.2010.2043039
Evaluation of three-level rectifiers for lowvoltage utility applications, IEEE Transactions on Industrial Electronics, pp.471-481, 2005. ,
A Comparison of Three-Level Converters Versus Two-Level Converters for Low-Voltage Drives, Traction, and Utility Applications, IEEE Transactions on Industry Applications, vol.41, issue.3, pp.855-865, 2005. ,
DOI : 10.1109/TIA.2005.847285
Modeling and Control of Neutral-point Voltage Balancing Problem in Three-level NPC PWM Inverters, IEEE 36th Conference on Power Electronics Specialists, 2005., pp.861-866, 2005. ,
DOI : 10.1109/PESC.2005.1581728
Neutral Point Potential Balancing Algorithm at Low Modulation Index for Three-Level Inverter Medium-Voltage Drives, IEEE Transactions on Industry Applications, vol.43, issue.3, pp.761-768, 2007. ,
DOI : 10.1109/TIA.2007.895767
Study of neutral point potential variation for threelevel NPC inverter under fault condition, Proc. 34 th IEEE IECON, pp.983-988, 2008. ,
Three-Level Converter Topologies With Switch Breakdown Fault-Tolerance Capability, IEEE Transactions on Industrial Electronics, vol.55, issue.3, pp.982-995, 2008. ,
DOI : 10.1109/TIE.2008.917072
Strategies of fault tolerant operation for three-level PWM inverters, IEEE Transactions on Power Electronics, vol.21, issue.4, pp.933-940, 2006. ,
DOI : 10.1109/TPEL.2006.876867
Analysis and Design of Active NPC (ANPC) Inverters for Fault-Tolerant Operation of High-Power Electrical Drives, IEEE Transactions on Power Electronics, vol.27, issue.2, pp.519-533, 2012. ,
DOI : 10.1109/TPEL.2011.2143430
Performance Evaluation of Fault-Tolerant Neutral-Point-Clamped Converters, IEEE Transactions on Industrial Electronics, vol.57, issue.8, pp.2709-2718, 2010. ,
DOI : 10.1109/TIE.2009.2026710
High-Power Converters and AC Drives, 2006. ,
DOI : 10.1002/9781119156079
