Design and Practice of an Elevator Control System Based on PLC, 2008 Workshop on Power Electronics and Intelligent Transportation System, pp.94-99, 2008. ,
DOI : 10.1109/PEITS.2008.44
FPGA implementation of dispatching algorithms for Local Control of Elevator Systems, 2008 IEEE International Symposium on Industrial Electronics, pp.1997-2002, 2008. ,
DOI : 10.1109/ISIE.2008.4677210
Sensor-aware elevator scheduling for smart building environments, Building and Environment, vol.72, pp.332-342, 2014. ,
DOI : 10.1016/j.buildenv.2013.11.013
Cyber-physical Systems: A Perspective at the Centennial, Proceedings of the IEEE, pp.1278-1308, 2012. ,
Complex events and actions to control cyber-physical systems, Proceedings of the 5th ACM international conference on Distributed event-based system, DEBS '11, pp.29-38, 2011. ,
DOI : 10.1145/2002259.2002265
Development of a Real Time Monitoring and Control System for PLC Based Elevator, 14th European Conference on Power Electronics and Applications, pp.1-8, 2011. ,
Formulations and Optimal Solution Algorithms for the Multifloor Layout Problem with Elevators In: IIE Annual Conference and Expo: Industrial Engineering's Critical Role in a Flat World, pp.1446-1452, 2007. ,
Heuristic algorithm to solve the multi-floor layout problem with the consideration of elevator utilization, Computers & Industrial Engineering, vol.36, issue.2, pp.487-502, 1999. ,
DOI : 10.1016/S0360-8352(99)00144-8
Floor Circulation Index and Optimal Positioning of Elevator Hoistways, Knowledge-Based and Intelligent Information and Engineering Systems, pp.331-340, 2010. ,
DOI : 10.1007/978-3-642-15390-7_34
A Hybrid Approach for the Analysis and Prediction of Elevator Passenger Flow in an Office Building Automation in Construction, pp.69-78, 2013. ,
A Survey of Elevator Group Control Systems for Vertical Transportation: A Look at Recent Literature, IEEE Control Systems, vol.35, issue.4, pp.38-55, 2015. ,
DOI : 10.1109/MCS.2015.2427045
Design of Elevator Control Systems using Statecharts, 10th IEEE International Conference on Networking, Sensing and Control, pp.322-327, 2013. ,
The impact of sensors' implementation on lift control system, Proceedings of IEEE East-West Design & Test Symposium (EWDTS 2014), pp.217-219, 2014. ,
DOI : 10.1109/EWDTS.2014.7027077
