Multi-Criteria Decision Making Methods, Multi-criteria Decision Making Methods: A Comparative Study, pp.5-21, 2000. ,
DOI : 10.1007/978-1-4757-3157-6_2
Improving the materials selection process in engineering design Impact of Data Normalization on Stock Index Forecasting Data Normalization Techniques in Decision Making: Case Study with TOPSIS Method Collaborative Systems for Smart Environments: Trends and Challenges A scaling method for priorities in hierarchical structures The Analytic Hierarchy Process Evaluating attack helicopters by AHP based on linguistic variable weight, Mater. Des. Int. J. Comput. Inf. Syst. Ind. Manag. Appl. Int. J. Inf. Decis. Sci. Collab. Syst. Smart Networked Environ. J. Math. Psychol. Eur. J. Oper. Res, vol.659, issue.116, pp.335-342, 1977. ,
Managing risks in the supply chain using the AHP method The analytic hierarchy process ? a survey of the method and its applications, Int. J. Logist. Manag. Interfaces (Providence), vol.1711, issue.16 4, pp.114-136, 1986. ,
An analytic network process approach for locating undesirable facilities: An example from Istanbul, Turkey, Saaty and L. G. Vargas, Models, Methods, Concepts & Applications of the Analytic Hierarchy Process. Maryland, USA: Institute for Operations Research and the Management Sciences Tzeng and J.-J. Huang, Multiple Attribute Desicion Making: Methods and Applications. Taylor & Frncis Group, pp.970-983, 2006. ,
DOI : 10.1016/j.jenvman.2007.05.004
Comparative Analysis of Normalization Procedures in TOPSIS Method: With an Application to Turkish Deposit Banking Market, INFORMATICA, vol.25, issue.2, pp.185-208, 2014. ,
A survey of Cyber-Physical Systems, 2011 International Conference on Wireless Communications and Signal Processing (WCSP), 2011. ,
DOI : 10.1109/WCSP.2011.6096958
Normalization (statistics) Available: https] Wiki3 Normalization Available: https://en.wikipedia.org/wiki/Normalization. [Accessed: 15 Normalization affects the results of MADM methods Data Normalization and Standardization, Normalization_%28statistics%29. Yugosl. J. Oper. Res, vol.1111, issue.2011, pp.251-265, 2011. ,
A Simulation Based Comparative Study of Normalization Procedures in Multiattribute Decision Making, Int. Conf. on Artificial Intelligence, Knowledge Engineering and Data Bases, pp.102-109, 2007. ,
A Simulation Comparison of Normalization Procedures for TOPSIS Rank Similarity based MADM Method Selection, International Conference on Statistics in Science, Business and Engineering (ICSSBE2012), pp.1815-1820, 2009. ,
The effect of normalization norms in multiple attribute decision making models: a case study in gear material selection, Structural and Multidisciplinary Optimization, vol.29, issue.4, pp.312-318, 2004. ,
DOI : 10.1007/s00158-004-0473-1
Investigating the Effect of Normalization Norms in Flexible Manufacturing Sytem Selection Using Multi-Criteria Decision-Making Methods, J. Eng. Sci. Technol, pp.141-150, 2014. ,
