A WLS Estimator for Target Localization in a Cooperative Wireless Sensor Network
This paper addresses target localization problem in a cooperative 3-D wireless sensor network (WSN). We employ non-traditional methodology which merges distance and angle measurements, respectively withdrawn from the received signal strength (RSS) and angle-of-arrival (AoA) information. Based on RSS measurement model and effortless geometry, a novel non-convex estimator according to the weighted least squares (WLS) criterion is obtained, which closely approximates the maximum likelihood (ML) estimator for small noise. It is shown that the devised estimator is appropriate for distributed implementation. Following the squared range (SR) approach, we propose a suboptimal SR-WLS estimator according to the generalized trust region sub-problem (GTRS) framework, to estimate the locations of all targets in the WSN. According to our simulations, the new estimator has excellent performance in a great variety of considered settings, in which the effectiveness of fusing two radio measurements is confirmed.
