Naturally Commutated and Clamped Softswitching Current-fed Push-pull Voltage Doubler Based Solar PV Inverter, IEEE 23 rd International Symposium on Industrial Electronics (ISIE), pp.2631-2636, 2014. ,
Grid-Connected Photovoltaic Generation Plants: Components and Operation, IEEE in Industrial Electronics Magazine, pp.6-20, 2013. ,
DOI : 10.1109/MIE.2013.2264540
URL : http://hdl.handle.net/11441/23524
Grid-connected photovoltaic power plants for helping node voltage regulation, IET Renewable Power Generation, pp.236-244 ,
DOI : 10.1049/iet-rpg.2014.0086
Helping all generations of photo-voltaic inverters ride-through voltage sags, IET Power Electronics, pp.2555-2563, 2014. ,
DOI : 10.1049/iet-pel.2013.0552
Three-phase single stage photovoltaic inverter with active filtering capabilities, IECON 2012, 38th Annual Conference on IEEE Industrial Electronics Society, pp.5253-5258, 2012. ,
DOI : 10.1109/IECON.2012.6389542
Evaluation of Storage Energy Requirements for Constant Production in PV Power Plants, IEEE Transactions on Industrial Electronics, vol.60, issue.3, pp.1225-1234, 2013. ,
DOI : 10.1109/TIE.2012.2202353
Distributed smart metering by using power electronics systems, Conference proceeding in IEEE 23 rd Int Symp. Industrial Electronics (ISIE), 2008. ,
DOI : 10.1109/isie.2014.6864925
URL : https://hal.archives-ouvertes.fr/hal-01274788
Z-source/quasi-Z-source inverters: derived networks, modulations, controls, and emerging applications to photovoltaic conversion, pp.32-44, 2014. ,
Impedance-Source Networks for Electric Power Conversion Part I: A Topological Review, IEEE Transactions on Power Electronics, vol.30, issue.2, pp.699-716, 2015. ,
DOI : 10.1109/TPEL.2014.2313746
URL : http://vbn.aau.dk/da/publications/impedancesource-networks-for-electric-power-conversion-part-i(a9346216-a943-4398-9f83-032a5205689b).html
Impedance-Source Networks for Electric Power Conversion Part II: Review of Control and Modulation Techniques, IEEE Transactions on Power Electronics, vol.30, issue.4, pp.1887-1906, 2015. ,
DOI : 10.1109/TPEL.2014.2329859
Frede Blaabjerg and Fang Zheng Peng " A Review of Galvanically Isolated Impedance-Source DC?DC Converters, IEEE Transactions on Power Electronics, vol.31, issue.4, 2016. ,
Janis Zakis, Overview of Impedance Source Networks for Voltage Source Inverters, pp.514-519 ,
Low-Cost Semi-Z-source Inverter for Single-Phase Photovoltaic Systems, IEEE Transactions on Power Electronics, vol.26, issue.12, 2011. ,
DOI : 10.1109/TPEL.2011.2148728
Z-source inverter, IEEE Transactions on Industry Applications, vol.39, issue.2, pp.504-510, 2003. ,
DOI : 10.1109/TIA.2003.808920
Trans-Z-Source Inverters, IEEE Transactions on Power Electronics, vol.26, issue.12, 2011. ,
DOI : 10.1109/tpel.2011.2122309
Galvanically Isolated Quasi-Z-Source DC–DC Converter With a Novel ZVS and ZCS Technique, IEEE Transactions on Industrial Electronics, vol.62, issue.12, pp.7547-7556, 2015. ,
DOI : 10.1109/TIE.2015.2455522
Wide Range ZVS Active- Clamped L-L Type Current-Fed DC-DC Converter for Fuel Cells to Utility Interface: Analysis, Design and Experimental Results, Energy Conversion Congress and Exposition, pp.1153-1160, 2009. ,
Naturally Clamped Zero-Current Commutated Soft-Switching Current-Fed Push–Pull DC/DC Converter: Analysis, Design, and Experimental Results, IEEE Transactions on Power Electronics, vol.30, issue.3, 2015. ,
DOI : 10.1109/TPEL.2014.2315834
Novel soft-switching snubberless naturally clamped current-fed full-bridge front-end converter based bidirectional inverter for, microgrid and UPS application, IEEE Transactions on Industrial Electronics, pp.2729-2736, 2013. ,
DOI : 10.1109/ecce.2013.6647054
Analysis, Design, and Experimental Results of a Novel Soft-Switching Snubberless Current-Fed Half-Bridge Front-End Converter- Based PV Inverter, IEEE Transactions on Power Electronics, vol.28, issue.7, 2013. ,
