Abstract : In this paper, the aim of automatically generating a cyber-physical control system (more precisely, an IEC61499 control system) is discussed. The method is enabled by ontology models, specifically the source plant ontology model and the target control model for the CPS system implemented in the preferred programming language. The transforming of ontologies is enabled by an extension of SWRL (called eSWRL) and it is introduced here. There interpreter of eSWRL is developed using the Prolog language. A case study Baggage Handling System is used to demonstrate how the ontology models are transformed and the corresponding transforming rules that are developed.
https://hal.inria.fr/hal-01438280 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, January 17, 2017 - 3:38:53 PM Last modification on : Wednesday, November 3, 2021 - 6:55:32 AM Long-term archiving on: : Tuesday, April 18, 2017 - 3:05:53 PM
Chen-Wei Yang, Valeriy Vyatkin, Victor Dubinin. Automatic Generation of Cyber-Physical Software Applications Based on Physical to Cyber Transformation Using Ontologies. 7th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Apr 2016, Costa de Caparica, Portugal. pp.37-45, ⟨10.1007/978-3-319-31165-4_4⟩. ⟨hal-01438280⟩
