Introduction To Flat Panel Displays, 2008. ,
Transparent semiconducting oxides: materials and devices. Phys. status solidi, pp.1437-1449, 2010. ,
DOI : 10.1002/pssa.200983771
Transparent thin film transistors using ZnO as an active channel layer and their electrical properties, Journal of Applied Physics, vol.93, issue.3, pp.1624-1630, 2003. ,
DOI : 10.1063/1.1534627
Transparent ZnO thin-film transistor fabricated by rf magnetron sputtering, Applied Physics Letters, vol.82, issue.7, p.1117, 2003. ,
DOI : 10.1063/1.1553997
ZnO-channel thin-film transistors: Channel mobility, Journal of Applied Physics, vol.95, issue.10, pp.5813-5819, 2004. ,
DOI : 10.1063/1.1712015
Wide-bandgap high-mobility ZnO thin-film transistors produced at room temperature, Applied Physics Letters, vol.85, issue.13, p.2541, 2004. ,
DOI : 10.1063/1.1790587
Room-temperature fabrication of transparent flexible thin-film transistors using amorphous oxide semiconductors, Nature, vol.26, issue.7016, pp.488-492, 2004. ,
DOI : 10.1002/adma.200304947
High-performance ZnO thin film transistors with sputtering SiO2/Ta2O5/SiO2 multilayer gate dielectric, Thin Solid Films, vol.518, issue.21, pp.6130-6133, 2010. ,
DOI : 10.1016/j.tsf.2010.06.017
Transparent ring oscillator based on indium gallium oxide thin-film transistors, Solid-State Electronics, vol.50, issue.3, pp.500-503, 2006. ,
DOI : 10.1016/j.sse.2006.02.004
Fast Thin-Film Transistor Circuits Based on Amorphous Oxide Semiconductor, IEEE Electron Device Letters, vol.28, issue.4, pp.273-275, 2007. ,
DOI : 10.1109/LED.2007.893223
Transparent Flexible Circuits Based on Amorphous-Indium–Gallium–Zinc–Oxide Thin-Film Transistors, IEEE Electron Device Letters, vol.32, issue.2, pp.170-172, 2011. ,
DOI : 10.1109/LED.2010.2093504
A 6b 10MS/s current-steering DAC manufactured with amorphous Gallium-Indium-Zinc-Oxide TFTs achieving SFDR > 30dB up to 300kHz, 2012 IEEE International Solid-State Circuits Conference, pp.2012-314, 2012. ,
DOI : 10.1109/ISSCC.2012.6177028
Simple Noise Margin Model for Optimal Design of Unipolar Thin-Film Transistor Logic Circuits, IEEE Transactions on Electron Devices, vol.60, issue.5, pp.1782-1785, 2013. ,
DOI : 10.1109/TED.2013.2251346
16.3 Flexible thin-film NFC tags powered by commercial USB reader device at 13.56MHz, 2015 IEEE International Solid-State Circuits Conference, (ISSCC) Digest of Technical Papers, pp.2015-2016, 2015. ,
DOI : 10.1109/ISSCC.2015.7063042
A Second-Order ?? ADC Using Sputtered IGZO TFTs, 2016. ,
DOI : 10.1007/978-3-319-27192-7
Ieee: Amorphous Silicon 5 Bit Flash Analog to Digital Converter, Ieee Cust. Integr. Circuits Conf, 2012. ,
DOI : 10.1109/cicc.2012.6330647
A CBSC second-order sigma-delta modulator in 3 µm LTPS-TFT technology, IEEE Asian Solid-State Circuits Conference, pp.133-136, 2009. ,
A Fully Integrated <formula formulatype="inline"> <tex Notation="TeX">$\Delta \Sigma$</tex></formula> ADC in Organic Thin-Film Transistor Technology on Flexible Plastic Foil, IEEE Journal of Solid-State Circuits, vol.46, issue.1, pp.276-284, 2011. ,
DOI : 10.1109/JSSC.2010.2073230
Design of a robust generalpurpose low-offset comparator based on IGZO thin-film transistors, 2015 IEEE International Symposium on Circuits and Systems (ISCAS), pp.261-264, 2015. ,
