Electrolyte-Gated Transistors for Organic and Printed Electronics, Advanced Materials, vol.95, issue.13, p.1822, 2013. ,
DOI : 10.1002/adma.201202790
Organic Bioelectronics, Advanced Materials, vol.600, issue.20, pp.3201-3213, 2007. ,
DOI : 10.1002/adma.200700419
Polyelectrolyte-Gated Organic Complementary Circuits Operating at Low Power and Voltage, Advanced Materials, vol.11, issue.40, p.4684, 2011. ,
DOI : 10.1002/adma.201101757
Fiber-Embedded Electrolyte-Gated Field-Effect Transistors for e-Textiles, Advanced Materials, vol.127, issue.5, p.573, 2009. ,
DOI : 10.1002/adma.200802681
Electrochromic tungsten oxide films: Review of progress 1993-1998. Solar Energy Materials and Solar Cells, pp.201-262, 2000. ,
DOI : 10.1016/s0927-0248(99)00088-4
The pH-sensitive tungsten(VI) oxide-based microelectrochemical transistors, The Journal of Physical Chemistry, vol.91, issue.3, pp.648-654, 1987. ,
DOI : 10.1021/j100287a030
Progress in electrochromics: tungsten oxide revisited, Electrochimica Acta, vol.44, issue.18, pp.3005-3015, 1999. ,
DOI : 10.1016/S0013-4686(99)00016-X
Electrochromic materials and devices: present and future, Materials Chemistry and Physics, vol.77, issue.1, pp.117-133, 2003. ,
DOI : 10.1016/S0254-0584(01)00575-2
Electrochromism of W-oxide-based thin films: Recent advances. Solid State ionics, p.86, 2007. ,
Flexible and Transparent WO3 Transistor with Electrical and Optical Modulation, 2015. ,
DOI : 10.1002/aelm.201500030
Impedance Spectroscopy Theory, Experiment, and Applications, 2005. ,
EIS and differential capacitance measurements onto single crystal faces in different solutions, Journal of Electroanalytical Chemistry, vol.541, pp.1-11, 2003. ,
DOI : 10.1016/S0022-0728(02)01309-8
Vertical polyelectrolyte-gated organic field-effect transistors, Applied Physics Letters, vol.97, p.3, 2010. ,
