ATLAS User ' s Manual, pp.567-1000, 2013. ,
Sentaurus Device User Guide, Synopsis, 2009. ,
Modeling of amorphous InGaZnO4 thin film transistors and their subgap density of states, Applied Physics Letters, vol.92, issue.13, p.133503, 2008. ,
DOI : 10.1063/1.2857463
Modeling of amorphous InGaZnO thin-film transistors based on the density of states extracted from the optical response of capacitance-voltage characteristics, Applied Physics Letters, vol.93, issue.18, pp.4-7, 2008. ,
DOI : 10.1063/1.3013842
Influence of Deep States in Active Layers on the Performance of Amorphous In-Ga-Zn-O Thin Film Transistors, Proc. China Display, pp.356-359, 2011. ,
Effects of defect creation on bidirectional behavior with hump characteristics of InGaZnO TFTs under bias and thermal stress, Japanese Journal of Applied Physics, vol.54, issue.3S, pp.153-156, 2015. ,
DOI : 10.7567/JJAP.54.03CB03
Modeling and Characterization of the Abnormal Hump in n-Channel Amorphous-InGaZnO Thin-Film Transistors After High Positive Bias Stress, IEEE Electron Device Letters, vol.36, issue.10, pp.1047-1049, 2015. ,
DOI : 10.1109/LED.2015.2466232
Bulk Accumulation a-IGZO TFT for High Current and Turn-On Voltage Uniformity, IEEE Electron Device Letters, vol.34, issue.12, pp.1533-1535, 2013. ,
DOI : 10.1109/LED.2013.2284599
Investigating electron depletion effect in amorphous indium???gallium???zinc-oxide thin-film transistor with a floating capping metal by technology computer-aided design simulation and leakage reduction, Japanese Journal of Applied Physics, vol.53, issue.6, p.64302, 2014. ,
DOI : 10.7567/JJAP.53.064302
Gas sensing properties of indium???gallium???zinc???oxide gas sensors in different light intensity, Analytical Chemistry Research, vol.4, pp.8-12, 2015. ,
DOI : 10.1016/j.ancr.2015.03.001
An IGZO TFT based in-cell capacitance touch sensor, 2012 IEEE 11th International Conference on Solid-State and Integrated Circuit Technology, pp.5-7, 2012. ,
DOI : 10.1109/ICSICT.2012.6467843
IGZO thin film transistor biosensors functionalized with ZnO nanorods and antibodies, Biosensors and Bioelectronics, vol.54, pp.306-316, 2014. ,
DOI : 10.1016/j.bios.2013.10.043
A Second-Order ?? ADC Using Sputtered IGZO TFTs, 2015. ,
DOI : 10.1007/978-3-319-27192-7
Self-aligned top-gate InGaZnO thin film transistors using SiO2/Al2O3 stack gate dielectric, Thin Solid Films, vol.548, pp.572-575, 2013. ,
DOI : 10.1016/j.tsf.2013.09.020
Characteristics of short-channel amorphous In-Ga-Zn-O thin film transistors and their circuit performance as a load inverter, Journal of Electroceramics, vol.29, issue.1, pp.74-79, 2012. ,
DOI : 10.1007/s10832-011-9680-5
Energetics of native defects in ZnO, Journal of Applied Physics, vol.90, issue.2, p.3665, 2001. ,
DOI : 10.1063/1.1380994
