178 Carlos Carvalho and Nuno Paulino Control and Fault Tolerance Initial Study on Fault Tolerant Control with Actuator Failure Detection for a Multi Motor Electric Vehicle 197 Bruno dos Santos and Rui Esteves Araújo Fault Analysis of Three-Level NPC Inverters in Synchronous Reluctance Motor Drives, Indoor Light Energy Harvesting System for Wireless Sensing Applications, p.206 ,
Marques Cardoso Analysis of Lift Control System Strategies Under Uneven Flow of Passengers, p.217 ,
and Yuriy Vagapov Scalar Variable Speed Motor Control for Traction Systems with Torque and Field Orientation Filter, 226 Paulo Mendonça and Duarte M. Sousa Optimization and Decision Support Variation-Aware Optimisation for Reconfigurable Cyber-Physical Systems, p.237 ,
Bouganis Virtual Reference Feedback Tuning of MIMO Data-Driven Model-Free Adaptive Control Algorithms, p.253 ,
Petriu Normalization Techniques for Multi-Criteria Decision Making: Analytical Hierarchy Process Case Study, 261 Nazanin Vafaei, Rita A. Ribeiro, and Luis M. Camarinha-Matos Wireless Technologies ,
273 Slavisa Tomic, Marko Beko, Rui Dinis, and Milan Tuba Effective Over-the-Air Reprogramming for Low-Power Devices in Cyber-Physical Systems, 284 Ondrej Kachman and Marcel Balaz Contents XIII Electromagnetic Interference Impact of Wireless Power Transfer System on Data Wireless Channel, p.293 ,
Pires Real-Time Estimation of the Interference in Random Waypoint Mobile Networks, 302 Luis Irio and Rodolfo Oliveira Energy -Smart Grids ,
Henrique Lopes Cardoso, and Eugénio Oliveira Computational Models Development and Demand Response Application for Smart Grids, p.340 ,
and Mário Ventim-Neves Renewable Energy Control and Supervision of Wind Energy Conversion Systems, p.353 ,
Carlos Roncero-Clemente, and Enrique Romero-Cadaval Contributions to the Design of a Water Pumped Storage System in an Isolated Power System with High Penetration of Wind Energy, p.378 ,
Mohamed Greenhouse with Sustainable Energy for IoT, p.416 ,
Sousa, and Mário Ventim Neves Impact of Self-consumption and Storage in Low Voltage Distribution Networks: An Economic Outlook, p.446 ,
Fernão Pires Demand Side Management Energy Management System for Distributed Networks, p.455 ,
Igreja, and Rui Neves-Silva Optimization in Energy Management Optimal Wind Bidding Strategies in Day-Ahead Markets, p.475 ,
Sousa Optimal Bidding Strategies of Wind-Thermal Power Producers, Mendes Bio-energy Wastewaters Reuse for Energy Crops Cultivation, p.507 ,
Removal of Chromium and Aluminum from Aqueous Solutions Using Refuse Derived Char, 515 Catarina Nobre, Margarida Gonçalves, Dieimes Resende, Cândida Vilarinho, and Benilde Mendes Bioremediation of Agro-industrial Effluents Using Chlorella Microalgae . . . . 523 ,
Liliana Soares, and Benilde Mendes Flexible and Transparent Oxide Electronics Oxide TFTs on Flexible Substrates for Designing and Fabricating Analog-to-Digital Converters, p.533 ,
Barquinha Contents XV Electrochemical Transistor Based on Tungsten Oxide with Optoelectronic Properties, p.542 ,
Rodrigo Martins, and Elvira Fortunato TCAD Simulation of Amorphous Indium-Gallium-Zinc Oxide Thin-Film Transistors, p.551 ,
