CFD Vision, 2030. ,
doi:2060/20140003093. 2 Fast Adaptive Aerospace Tools (FAAST) Development Team Opportunities for Breakthroughs in Large-Scale Computational Simulation and Design NASA TM-211747, Study: A Path to Revolutionary Computational Aerosciences The TOP500 List and Progress in High-Performance Computing, pp.42-49, 2002. ,
Achievement of Global Second Order Mesh Convergence for Discontinuous Flows with Adapted Unstructured Meshes AIAA Paper Mesh Adaptation as a Tool for Certified Computational Aerodynamics The Importance of Mesh Adaptation for Higher-Order Discretizations of Aerodynamic Flows, International Journal for Numerical Methods in Fluids, vol.45, issue.2 7, pp.179-196, 2004. ,
Certifiable Computational Fluid Dynamics Through Mesh Optimization, AIAA Journal, vol.36, issue.5, pp.703-711, 1998. ,
DOI : 10.2514/2.458
Grid Quality and Resolution Issues from the Drag Prediction Workshop Series DPW : Reflections from an Outsider or The RANS' Elusive Asymptotic Range! AIAA Paper Verification and Validation in Computational Fluid Dynamics Three?Dimensional Turbulent RANS Adjoint?Based Error Correction AIAA Paper Output-Based Adaptive Meshing Applied to Space Launch System Booster Separation Analysis AIAA Paper Inviscid and Viscous CFD Analysis of Booster Separation for the Space Launch System Vehicle Further Studies of Airfoils Supporting Non-Unique Solutions in Transonic Flow Strategies for Turbulence Modelling and Simulations, Progress in Aerospace Sciences Numerical Evidence of Multiple Solutions for the Reynolds?Averaged Navier?Stokes Equations for High?Lift Configurations CFL3D, FUN3D, and NSU3D Contributions to the Fifth Drag Prediction Workshop, pp.935-950, 1016. ,
Anisotropic Adaptation for Transonic Flows with Turbulent Boundary Layers Comparison of Viscous Grid Layer Growth Rate of Unstructured Grids on CFD Drag Prediction Workshop Results AIAA Paper Three-Dimensional Unstructured Viscous Grids by the Advancing-Layers Method Turbulent Output-Based Anisotropic Adaptation AIAA Paper Low Boom Configuration Analysis with FUN3D Adjoint Simulation Framework AIAA Paper The Prospect of Using Large Eddy and Detached Eddy Simulations in Engineering Design, and the Research Required to Get There Towards Full Aircraft Airframe Noise Prediction: Detached Eddy Simulations AIAA Paper Evaluation of Airframe Noise Reduction Concepts via Simulations Using a Lattice Boltzmann Approach AIAA Paper Open Rotor Computational Aeroacoustic Analysis with an Immersed Boundary Method Thirty Years of Development and Application of CFD at Boeing Commercial Airplanes Aerodynamic Shape Optimization Benchmarks with Error Control and Automatic Parameterization AIAA Paper Status and Future of Geometry Modeling and Grid Generation for Design and Optimization AIAA Paper Computational and Experimental Unsteady Pressures for Alternate SLS Booster Nose Shapes Toward Automatic Verification of Goal-Oriented Flow Simulations Recent Advancements in the Helios Rotorcraft Simulation Code A Decade of Progress on Anisotropic Mesh Adaptation for Computational Fluid Dynamics Anisotropic Mesh Adaptation: Towards User-Independent, Mesh-Independent and Solver-Independent CFD. Part I: General Principles Anisotropic 3-D Mesh Adaptation on Unstructured Hybrid Meshes On 3D Anisotropic Local Remeshing for Surface, Volume and Boundary Layers Parallel Anisotropic 3D Mesh Adaptation by Mesh Modification Anisotropic Mesh Adaptation Through Edge Primitive Operations Metric-Orthogonal Anisotropic Mesh Generation Alignment and Orthogonality in Anisotropic Metric-Based Mesh Adaptation, Exploration Agency Studies for the Fifth AIAA Drag Prediction Workshop Analysis of the Common Research Model Using Structured and Unstructured Meshes6<725::AID-FLD935>3.0.CO;2-4. 38 Suerich- Mesh Modification Procedures for General 3-D Non-Manifold Domains 40 Park, M. A., Anisotropic Output-Based Adaptation with Tetrahedral Cut Cells for Compressible Flows 18th International Meshing Roundtable, Sandia National Laboratories. 43 Gorman, G., Parallel Anisotropic Unstructured Mesh Optimization and its Applications Serial and Parallel Mesh Modification Through a Unique Cavity-Based Primitive, " 22nd International Meshing Roundtable, Sandia National Laboratories Procedia Engineering, 23rd International Meshing Roundtable, Sandia National Laboratories, pp.1244-1267, 1719. ,
What Is a Good Linear Element? Interpolation, Conditioning, and Quality Measures, 11th International Meshing Roundtable, Sandia National Laboratories, pp.115-126, 2002. ,
Automated adaptive cardiovascular flow simulations Finite Element Analysis of Boundary Layer Flows using a Mixed B-spline Setting on Hybrid Meshes AIAA Paper Viscous Flow Analysis Using a Parallel Unstructured Multigrid Solver Hybrid Grid Adaptation in TAU MEGAFLOW -Numerical Flow Simulation for Aircraft Design of Notes on Numerical Fluid Mechanics and Multidisciplinary Design Adaptive Prismatic-Tetrahedral Grid Refinement and Redistribution for Viscous Flows Adaptive Boundary Layer Meshing for Viscous Flow Simulations Accessing CAD Geometry for Mesh Generation Unified Geometry Access for Analysis and Design Surface Remeshing with Robust High-Order Reconstruction Parallel Dynamic Load-Balancing Algorithm for, 12th International Meshing Roundtable, Sandia National Laboratories 12th International Meshing Roundtable, Sandia National Laboratories, pp.25-36, 1099. ,
Parallel Structures and Dynamic Load Balancing for Adaptive Finite Element Computation, Dimensional Adaptive Unstructured Grids, pp.497-505, 1994. ,
Tools to support mesh adaptation on massively parallel computers, Engineering with Computers, vol.190, issue.16, pp.287-301, 2012. ,
DOI : 10.1007/s00366-011-0218-x
Parallel Adaptation of General Three-Dimensional Hybrid Meshes Extreme-Scale Parallel Mesh Generation: Telescopic Approach Towards Exascale Parallel Delaunay Mesh Generation doi:10.1007/978-3-642-04319-2 19 High-Order Methods for the Euler and Navier-Stokes Equations on Unstructured Grids High-Order CFD Methods: Current Status and Perspective Validation and Generation of Curved Meshes for High-Order Unstructured Methods meshCurve: An Automated Low-Order to High-Order Mesh Generator Regridding Surface Triangulations Adaptive Mesh Generation for Curved Domains Curved Mesh Generation and Mesh Refinement using Lagrangian Solid Mechanics Robust Untangling of Curvilinear Meshes Moving Curved Mesh Adaptation for Higher-Order Finite Element Simulations Curved Boundary Layer Meshing for Adaptive Viscous Flow Simulations, Dynamic Load Balancing 24th International Meshing Roundtable Technical Poster, Sandia National Laboratories 18th International Meshing Roundtable, Sandia National Laboratories Progress in Aerospace Sciences Review of Output-Based Error Estimation and Mesh Adaptation in Computational Fluid Dynamics, pp.133-152, 1996. ,
Continuous Mesh Framework Part I: Well-Posed Continuous Interpolation Error Metric Construction by Length Distribution Tensor and Edge Based Error for Anisotropic Adaptive Meshing Anisotropic hp-Adaptive Method Based on Interpolation Error Estimates in the L q -Norm Grid Convergence for Adaptive Methods AIAA Paper 91?1592 Recent Advances in Agglomerated Multigrid AIAA Paper 2013?863 Unicorn: Parallel Adaptive Finite Element Simulation of Turbulent Flow and Fluid?Structure Interaction for Deforming Domains and Complex Geometry Computers and Fluids Parallel Adaptive Detached Eddy Simulations of the EUROLIFT DLR-F11 High Lift Configuration AIAA Paper P1-Conservative Solution Interpolation on Unstructured Triangular Meshes Metric-Based Anisotropic Mesh Adaptation for Three-Dimensional Time- Dependent Problems Involving Moving Geometries AIAA Paper Executive Order ? Creating a National Strategic Computing Initiative https://www. whitehouse.gov/the-press-officeexecutive-order-creating-national-strategic-computing-initiative Grid Convergence for Turbulent Flows AIAA Paper Reference Solutions for Benchmark Turbulent Flows in Three Dimensions AIAA Paper Pseudo-transient Continuation, Solution Update Methods, and CFL Strategies for DG Discretizations of the RANS-SA Equations AIAA Paper Advances in Numerical Methods for CREATE-AV Analysis Tools MOAB: A Mesh-Oriented Database A Parallel Unstructured Mesh Infrastructure, " 2012 SC Companion: High Performance Computing, Networking Storage and Analysis Practical and Reliable Mesh Generation for Complex, Real-world Geometries Towards Goal-Oriented Mesh Adaptation for Fluid-Structure Interaction Sonic Boom Mitigation Through Aircraft Design and Adjoint Methodology An Overview of Combined Uncertainty and A Posteriori Error Bound Estimates for CFD Calculations A Posteriori Control of Modeling Errors and Discretization Errors Robust Grid Adaptation for Ecient Uncertainty Quantification Resilience Engineering: Learning to Embrace Failure, Based Framework for Anisotropic Simplex Mesh Adaptation An Optimization Framework for Adaptive Higher-Order Discretizations of Partial Di?erential Equations on Anisotropic Simplex Meshes Assessment of Preconditioner for a USM3D Hierarchical Adaptive Nonlinear Method (HANIM) VI International Conference on Computational Methods for Coupled Problems in Science and Engineering, Coupled Problems 2015 PreFail: A Programmable Failure-Injection Framework 105 Alauzet, F., " A Parallel Matrix-Free Conservative Solution Interpolation on Unstructured Tetrahedral Meshes Conservative Interpolation Between Volume Meshes by Local Galerkin Projection High-Order Sonic Boom Modeling Based on Adaptive Methods, pp.7626-7649, 1062. ,
Cartesian O?-Body Grid Adaption for Viscous Time-Accurate Flow Simulation AIAA Paper SPLITFLOW: A 3D Unstructured Cartesian/Prismatic Grid CFD Code for Complex Geometries AIAA Paper 1995?343 Turbulent Flow Simulation around Complex Geometries with Cartesian Grid Method AIAA Paper Progress Towards a Cartesian Cut-Cell Method for Viscous Compressible Flow Higher-Order and Adaptive Discontinuous Galerkin Methods with Shock-Capturing Applied to Transonic Turbulent Delta Wing Flow Drag Prediction Using Adaptive Discontinuous Finite Elements High-Order Output-Based Adaptive Simulations of Turbulent Flow in Two Dimensions Adaptive Remeshing for Compressible Flow Computations Adaptive Remeshing for Three-Dimensional Compressible Flow Computations Adaptive Unstructured Grid Generation for Viscous Flow Applications A Solution-Adaptive Unstructured Grid Method by Grid Subdivision and Local Remeshing, Anisotropic Mesh Adaptivity in CFDTheory and Applications Tetrahedral Mesh Improvement Using Swapping and Smoothing21<3979::AID-NME251>3.0.CO, pp.171-182, 1459. ,
Optimal Point Placement for Mesh Smoothing, 5th International Meshing Roundtable, Sandia National Laboratories, pp.302-322, 1996. ,
DOI : 10.1006/jagm.1998.0984
Adaptive Meshing Techniques for Viscous Flow Calculations on Mixed Element Unstructured Meshes, Anisotropic Tetrahedral Meshing via Bubble Packing and Advancing Front2<93::AID-FLD48>3 Parallel Refinement and Coarsening of Tetrahedral Meshes7<1101::AID-NME741>3.0.CO, pp.1923-1942, 1999. ,
High-Order Accurate Discontinuous Finite Element Solution of the 2D Euler Equations The Influence of Geometric Approximation on the Accuracy of High Order Methods Accounting for Curved Domains in Mesh Adaptation Triangulation of Arbitrary Polyhedra to Support Automatic Mesh Generators Cavity-Based Operators for Mesh Adaptation Scalable Multithreaded Algorithms for Mutable Irregular Data with Application to Anisotropic Mesh Adaptivity Parallel Adaptive Refinement for Unsteady Flow Calculations on 3D Unstructured Grids Parallel Unstructured Mesh Adaptation on Distributed-Memory Systems A Parallel Adaptation Package for Three-Dimensional Mixed-Element Unstructured Meshes Generic Components for Petascale Adaptive Unstructured Mesh-Based Simulations, Tetrahedral and Hexahedral Mesh Adaptation for CFD Problems Parallel Automated Adaptive Procedures for Unstructured Meshes CFD, No. R-807, pp.135-151, 1995. ,
Ecient Distributed Mesh Data Structure for Parallel Automated Adaptive Analysis FMDB: Flexible Distributed Mesh Database for Parallel Automated Adaptive Analysis Rensselaer Polytechnic Institute Large Displacement Body-Fitted FSI Simulations Using a Mesh-Connectivity-Change Moving Mesh Strategy AIAA Paper Unstructured Overset Mesh Adaptation with Turbulence Modeling for Unsteady Aerodynamic Interactions Adaptive Spacetime Meshing for Discontinuous Galerkin Methods Unstructured Grid Techniques Combined Feature-Driven Richardson-Based Adaptive Mesh Refinement for Unsteady Vortical Flows Feature-Based Adaptive Mesh Refinement for Wingtip Vortices Solution Adaptive Mesh Generation Using Feature-Aligned Embedded Surface Meshes Parallel, Gradient-Based Anisotropic Mesh Adaptation for Re-entry Vehicle Configurations Feature-Based and Output-Based Grid Adaptation Study for Hypersonic Propulsive Deceleration Jet Flows Anisotropic Unstructured Mesh Adaptation for Flow Simulations How a Nonconvergent Recovered Hessian Works in Mesh Adaptation Anisotropic Grid Adaptation for Functional Outputs: Application to, Parallel Anisotropic Mesh Adaptation with Boundary Layers 19th International Meshing Roundtable Research Notes, Sandia National Laboratories 153 Venditti, D. A., Grid Adaptation for Functional Outputs of Compressible Flow Simulations, pp.197-213, 1997. ,
Finite-Volume Goal-Oriented Mesh Adaptation for Aerodynamics Using Functional Derivative with Respect to Nodal Coordinates Heuristic a posteriori Estimation of Error Due to Dissipation in Finite Volume Schemes and Application to Mesh Adaptation Anisotropic Norm-Oriented Mesh Adaptation for Compressible Inviscid Flows AIAA Paper Multitarget Error Estimation and Adaptivity in Aerodynamic Flow Simulations Anisotropic Grid Adaptation for Multiple Aerodynamic Outputs Technical Report ACDL TR-07-1, Aerospace Computational Design Laboratory, Department of Aeronautics and Astronautics, Massachusetts Institute of Technology An Entropy Adjoint Approach to Mesh Refinement Transient Fixed Point-Based Unstructured Mesh Adaptation Time Accurate Anisotropic Goal-Oriented Mesh Adaptation for Unsteady Flows Summary of the First AIAA CFD High- Lift Prediction Workshop Impact of Triangle Shapes Using High-Order Discretizations and Direct Mesh Adaptation for Output Error , Master's thesis, Massachusetts Institute of Technology E?ects of Mesh Regularity on Accuracy of Finite-Volume Schemes Revisiting the Least-Squares Procedure for Gradient Reconstruction on Unstructured Meshes Accuracy of Gradient Reconstruction on Grids with High Aspect Ratio FUN3D and CFL3D Computations for the First High Lift Prediction Workshop Scaling Up Multiphysics Application of the FUN3D Solver to the 4th AIAA Drag Prediction Workshop Comparing Anisotropic Output-Based Grid Adaptation Methods by Decomposition Failure of Anisotropic Unstructured Mesh Adaption Based on Multidimensional Residual Minimization Verification of Three-Dimensional Anisotropic Adaptive Process On a Discrete Hessian Recovery for P1 Finite Elements Analysis of Hessian Recovery Methods for Generating Adaptive Meshes Size Gradation Control of Anisotropic Meshes, Dimensional Viscous FlowsCell Adaptive Method for High-Order Discretizations of the Compressible Navier-Stokes Equations An Interpolation Error Estimate on Anisotropic Meshes in R n and Optimal Metrics for Mesh Refinement On Hessian Recovery and Anisotropic Adaptivity European Conference on Computational Fluid Dynamics 15th International Meshing Roundtable, Sandia National Laboratories, pp.22-46, 1998. ,
Mesh Adaptation Strategies for Problems in Fluid Dynamics Finite Elements in Analysis and Design Unstructured Mesh Generation and Adaptivity, ICASE/LaRC Workshop on Adaptive Grid Methods, pp.181-202, 1995. ,
The Psychology of Cost Estimating Parallel Meshing and Remeshing Parallel Load Balancing for Dynamic Execution Environments An Optimal Control Approach to a posteriori Error Estimation in Finite Element Methods Tetrahedral Mesh optimisation and Adaptivity for Steady-State and Transient Finite Element Calculations Anisotropic Mesh Adaptation: Towards User-Independent, Mesh-Independent and Solver-Independent CFD. Part III. Unstructured Grids Grid Adaptation for Functional Outputs: Application to Two-Dimensional Inviscid Flows Adjoint?Based, Three?Dimensional Error Prediction and Grid Adaptation Adjoint?Based, Three?Dimensional Error Prediction and Grid Adaptation GridEx ? An Integrated Grid Generation Package for CFD Application of a Parallel Adjoint- Based Error Estimation and Anisotropic Grid Adaptation for Three-Dimensional Aerospace Configurations A Parallel Unstructured Dynamic Mesh Adaptation Algorithm for 3-D Unsteady Flows A Dynamic Adaptation Scheme for General 3-D Hybrid Meshes, On Anisotropic Mesh Generation and Quality Control in Complex Flow Problems 10th International Meshing Roundtable, Sandia National Laboratories doi:10.1017/S0962492901000010. 188 Pain, pp.341-349, 1995. ,
Validation of 3D Adjoint Based Error Estimation and Mesh Adaptation for Sonic Boom Prediction AIAA Paper Parallel Dynamic Grid Refinement for Industrial Applications Error Estimation and Grid Adaptation Using Euler Adjoint Method, European Conference on Computational Fluid Dynamics ECCOMAS CFD 2006, pp.1317-1324, 1150. ,
Output-Based Error Estimation and Adaptive Mesh Refinement Using Viscous Adjoint Method AIAA Paper 3D Transient Fixed Point Mesh Adaptation for Time- Dependent Problems: Application to CFD Simulations A Triangular Cut-Cell Adaptive Method for High-Order Discretizations of the Compressible Navier?Stokes Equations Recent Developments of TAU Adaptation Capability, Journal of Computational Physics Journal of Computational Physics, vol.222, issue.225 2, pp.592-623, 1395. ,
Algorithm Issues and Challenges Associated with the Development of Robust CFD Codes FUN3D Grid Refinement and Adaptation Studies for the Ares Launch Vehicle AIAA Paper Anisotropic Adaptive Simulations in Aerodynamics AIAA Paper Validation of an Output-Adaptive, Tetrahedral Cut-Cell Method for Sonic Boom Prediction Continuous Mesh Framework Part II: Validations and Applications Robust Boundary Layer Mesh Generation Parallel Adaptive Boundary Layer Meshing for CFD Analysis Computational and Experimental Assessment of Models for the First AIAA Sonic Boom Prediction Workshop Using High Fidelity CFD Methods with Mesh Adaptation Scalable Implicit Flow Solver for Realistic Wing Simulations with Flow Control Numerical Simulations For the F-16XL Aircraft Configuration Grid-Adapted FUN3D Computations for the Second High Lift Prediction Workshop Finite Element Flow Simulations of the EUROLIFT DLR-F11 High Lift Configuration A Changing-Topology Moving Mesh Technique for Large Displacements Parallel Generation of Large-size Adapted Meshes Aerodynamic Shape Optimization of a Dual-Stream Supersonic Plug Nozzle, Initiatives for Aerodynamic Simulation and Optimization in Aircraft Design of Notes on Numerical Fluid Mechanics and Multidisciplinary Design 21st International Meshing Roundtable, Sandia National Laboratories 21st International Meshing Roundtable, Sandia National Laboratories Numerical Methods and Mesh Adaptation for Reliable RANS Simulations Procedia Engineering, 24th International Meshing Roundtable, Sandia National Laboratories Thread Parallelism for Highly Irregular Computation in Anisotropic Mesh Adaptation Proceedings of the 3rd International Conference on Exascle Applications and Software, edited by A. Gray, L. Smith, and W. Weiland, pp.3-19, 1047. ,
Application of a Higher-order Adaptive Method to RANS Test Cases AIAA Paper Parallel Anisotropic Mesh Adaptation with Boundary Layers for Automated Viscous Flow Simulations Role of Computational Fluid Dynamics and Wind Tunnels in Aeronautics R&D Hybrid Corn: An Exploration in the Economics of Technological Change, Rodgers, E. M., Di?usion of Inventions, pp.10-1007, 1530. ,
The Pattern of Development and Di?usion of Breakthrough Communication Technologies Crossing the Chasm: Marketing and Selling Disruptive Products to Mainstream Customers The Market Evolution and Sales Takeo? of Product Innovations Adoption of New Technology Working Paper 9730 The Lean Startup: How Today's Entrepreneurs Use Continuous Innovation to Create Radically Successful Businesses, Crown Business Integrated Aerodynamic Benefits of Distributed Propulsion A Locally Refined Rectangular Grid Finite Element Method: Application to Computational Fluid Dynamics and Computational Physics GridTool: A Surface Modeling and Grid Generation Tool, New Product Growth for Model Consumer Durables The NASA Tetrahedral Unstructured Software System Proceedings of the Workshop on Surface Modeling, Grid Generation, and Related Issues in Computational Fluid Dynamic (CFD) Solutions, pp.215-227, 1500. ,
