T 1 mapping, AIF and Pharmacokinetic Parameter Extraction from Dynamic Contrast Enhancement MRI Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Dynamic contrast enhanced (DCE) magnetic resonance imaging (MRI) is a sensitive, noninvasive technique for the assessment of mi-crovascular properties of the tissue. Quantitative physiological parameters can be obtained using pharmacokinetic (PK) models that track contrast agents as it passes through the tissue vasculature. Such analysis usually requires prior knowledge of the voxels' T1 values and of the Arterial Input Function (AIF). Therefore, relaxometry T1 measurements are usually performed prior to contrast-agent injection and the AIF is manually or automatically extracted from the dynamic data. In this study, a method for a fully automatic analysis of DCE data for joint PK parameters , T1 mapping and AIF extraction is proposed. Results are shown on simulated data compared to other methods and on data acquired from healthy subjects and patients with Glioblastoma who received anti-angiogenic therapy. The proposed method renders DCE analysis to be robust and easily applicable.
gilad_miccai2011_MBIA_Final.pdf (167.12 Ko) Télécharger le fichier
hal-01439120 , version 1 (18-01-2017)
Gilad Liberman, Yoram Louzoun, Olivier Colliot, Dafna Ben Bashat. T 1 mapping, AIF and Pharmacokinetic Parameter Extraction from Dynamic Contrast Enhancement MRI Data. MICCAI Workshop on Multimodal Brain Image Analysis MBIA 2011, 2011, Toronto, Canada. pp.76 - 83, ⟨10.1007/978-3-642-24446-9_10⟩. ⟨hal-01439120⟩
125 Consultations
196 Téléchargements
