Nonlinear approximation of functions in two dimensions by sums of exponential functions, Applied and Computational Harmonic Analysis, vol.29, issue.2, pp.156-181, 2010. ,
DOI : 10.1016/j.acha.2009.08.009
Essai expérimental et analytique: Sur les lois de la dilatabilité de fluidesélastiquefluidesélastique et sur celles de la force expansive de la vapeur de l'alcool, ` a différentes températures, J. Ecole Polyt, vol.1, pp.24-76 ,
General tensor decomposition, moment matrices and applications, Journal of Symbolic Computation, vol.52, pp.51-71, 2013. ,
DOI : 10.1016/j.jsc.2012.05.012
URL : https://hal.archives-ouvertes.fr/inria-00590965
Newton influence with 5 iterations Symmetric tensor decomposition. Linear Algebra and Applications, Figure, vol.4, issue.433, pp.11-121851, 2010. ,
DOI : 10.1016/j.laa.2010.06.046
URL : http://doi.org/10.1016/j.laa.2010.06.046
The condition number of real Vandermonde, Krylov and positive definite Hankel matrices, Numerische Mathematik, vol.85, issue.4, pp.553-577, 1997. ,
DOI : 10.1007/PL00005392
On the numerical condition of a generalized Hankel eigenvalue problem, Numerische Mathematik, vol.13, issue.3, pp.41-68, 2007. ,
DOI : 10.1007/s00211-006-0054-x
On approximation of functions by exponential sums, Applied and Computational Harmonic Analysis, vol.19, issue.1, pp.17-48, 2005. ,
DOI : 10.1016/j.acha.2005.01.003
Polynomial and Matrix Computations, Birkhäuser Boston, 1994. ,
DOI : 10.1007/978-1-4612-0265-3
IntroductionàIntroductionà la résolution des systèmes polynomiaux, Mathématiques et Applications, vol.59, 2007. ,
DOI : 10.1007/978-3-540-71647-1
A Polynomial Approach to Linear Algebra. Universitext ,
Separable nonlinear least squares: the variable projection method and its applications, Inverse Problems, vol.19, issue.2, pp.1-26, 2003. ,
DOI : 10.1088/0266-5611/19/2/201
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.6.4497
Matrix pencil method for estimating parameters of exponentially damped/undamped sinusoids in noise, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.38, issue.5, pp.814-824, 1990. ,
DOI : 10.1109/29.56027
A multivariate generalization of Prony's method, Linear Algebra and its Applications, vol.490, pp.31-47, 2016. ,
DOI : 10.1016/j.laa.2015.10.023
Zur Theorie der Elimination Einer Variabeln aus Zwei Algebraischen Gleichungen, pp.535-600 ,
Tensors: Geometry and Applications. Graduate studies in mathematics, 2011. ,
DOI : 10.1090/gsm/128
Low Rank Approximation. Communications and Control Engineering, 2012. ,
DOI : 10.1007/978-1-4471-2227-2
Isolated points, duality and residues, Journal of Pure and Applied Algebra, vol.117, issue.118, pp.469-493, 1996. ,
DOI : 10.1016/S0022-4049(97)00023-6
URL : https://hal.archives-ouvertes.fr/inria-00125278
Polynomial-exponential decomposition from moments, 2016. hal-01367730 ,
Multivariate Polynomials, Duality, and Structured Matrices, Journal of Complexity, vol.16, issue.1, pp.110-180, 2000. ,
DOI : 10.1006/jcom.1999.0530
URL : https://hal.archives-ouvertes.fr/inria-00073171
How Bad Are Vandermonde Matrices?, SIAM Journal on Matrix Analysis and Applications, vol.37, issue.2, pp.676-694, 2016. ,
Prony's Method for Multivariate Signals, PAMM, vol.15, issue.1, pp.665-666, 2015. ,
DOI : 10.1002/pamm.201510322
Nonlinear approximation by sums of nonincreasing exponentials, Applicable Analysis, vol.90, issue.3-4, pp.609-626, 2011. ,
DOI : 10.1002/cem.1212
Parameter estimation for multivariate exponential sums, Electronic Transactions on Numerical Analysis, vol.40, pp.204-224, 2013. ,
ESPRIT-estimation of signal parameters via rotational invariance techniques, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.37, issue.7, pp.984-995, 1989. ,
DOI : 10.1109/29.32276
Prony???s method in several variables, Numerische Mathematik, vol.30, issue.4, 2016. ,
DOI : 10.1007/s10543-014-0533-x
URL : http://arxiv.org/abs/1602.02352
A performance analysis of subspace-based methods in the presence of model errors. I. The MUSIC algorithm, IEEE Transactions on signal processing, vol.40, issue.7, pp.1758-1774, 1992. ,
How bad are Hankel matrices? Numerische Mathematik, pp.261-269, 1994. ,
