New interface
Journal articles
Gold Dimer Nanoantenna with Slanted Gap for Tunable LSPR and Improved SERS
Abstract : We focus on improving the surface-enhanced Raman scattering (SERS) of dimer nanoantenna by tailoring the shape of the coupled nanoantennas extremities from rounded to straight or slanted ones. A numerical model based on the discrete dipole approximation method—taking into account periodicity, adhesion layer, and roughness—is first validated by comparison with localized surface plasmon resonance (LSPR) and SERS experiments on round-edged dimer nanoantennas and then used to investigate the effect of the straight or slanted gap in the dimer antenna. Simulations show that both LSPR and SERS can be tuned by changing the gap slanting angle. The SERS enhancement factor can also be improved by 2 orders of magnitude compared to the one reached using a rounded gap. Therefore, the slanting angle can be used as a new control parameter in the design of SERS substrates to guarantee stronger field confinement and higher sensitivity, especially as its feasibility is demonstrated.
Keywords : SERS
Complete list of metadata
https://hal.inria.fr/hal-01441511
Contributor : Dominique Barchiesi Connect in order to contact the contributor
Submitted on : Thursday, January 19, 2017 - 6:13:42 PM
Last modification on : Tuesday, November 29, 2022 - 4:10:54 AM
Identifiers
Citation
Sameh Kessentini, Dominique Barchiesi, Cristiano d'Andrea, Andrea Toma, Nicolas Guillot, et al.. Gold Dimer Nanoantenna with Slanted Gap for Tunable LSPR and Improved SERS. Journal of Physical Chemistry C, 2014, 118 (6), pp.3209-3219. ⟨10.1021/jp409844y⟩. ⟨hal-01441511⟩
Share
Metrics
Record views
237
