New interface
Journal articles
Numerical retrieval of thin aluminium layer properties from SPR experimental data
Abstract : The inverse problem for Surface Plasmon Resonance measurements [1] on a thin layer of aluminium in the Kretschmann configuration, is solved with a Particle Swarm Optimization method. The optical indexes as well as the geometrical parameters are found for the best fit of the experimental reflection coefficient in s and p polarization, for four samples, under three theoretical hypothesis on materials: the metal layer is pure, melted with its oxyde, or coated with oxyde. The influence of the thickness of the metal layer on its optical properties is then investigated.
Complete list of metadata
https://hal.inria.fr/hal-01441536
Contributor : Dominique Barchiesi Connect in order to contact the contributor
Submitted on : Thursday, January 19, 2017 - 6:33:58 PM
Last modification on : Sunday, June 26, 2022 - 4:50:24 AM
Links full text
Identifiers
Collections
Citation
Dominique Barchiesi. Numerical retrieval of thin aluminium layer properties from SPR experimental data. Optics Express, 2012, 20 (8), pp.9064--9078. ⟨10.1364/OE.20.009064⟩. ⟨hal-01441536⟩
Share
Metrics
Record views
175
