in a Tokamak for arbitrary shape of plasma pinch cross-section, Plasma Physics, vol.13, issue.9, p.757, 1971. ,
DOI : 10.1088/0032-1028/13/9/006
Magnetic analysis of non-circular cross-section tokamaks, Nuclear Fusion, vol.22, issue.6, pp.813-821, 1982. ,
DOI : 10.1088/0029-5515/22/6/009
An efficient technique for magnetic analysis of non-circular, high-beta tokamak equilibria, Nuclear Fusion, vol.22, issue.8, pp.1015-1030, 1982. ,
DOI : 10.1088/0029-5515/22/8/002
in tokamaks of non-circular cross-section, Nuclear Fusion, vol.25, issue.10, p.1421, 1985. ,
DOI : 10.1088/0029-5515/25/10/004
Numerical Simulation and Optimal Control in Plasma Physics with Applications to Tokamaks, Series in Modern Applied Mathematics, 1989. ,
URL: http://adsabs, Soviet Journal of Experimental and Theoretical Physics, vol.6, issue.545, 1958. ,
URL: http://scitation, Physics of Plasmas, vol.66, pp.3554-3560, 1999. ,
Equilibrium analysis of steady state tokamak discharges, Nuclear Fusion, vol.43, issue.9, pp.842-850, 2003. ,
DOI : 10.1088/0029-5515/43/9/308
Reconstruction of the equilibrium of the plasma in a Tokamak and identification of the current density profile in real time, Journal of Computational Physics, vol.231, issue.3, pp.960-980, 2012. ,
DOI : 10.1016/j.jcp.2011.04.005
URL : https://hal.archives-ouvertes.fr/hal-00419608
Tokamak equilibrium reconstruction code LIUQE and its real time implementation, Fusion Engineering and Design, vol.91, pp.1-15, 2015. ,
DOI : 10.1016/j.fusengdes.2014.09.019
URL : https://infoscience.epfl.ch/record/204582/files/LIUQEpaperCompact.pdf
Magnetic diagnostics: General principles and the problem of reconstruction of plasma current and pressure profiles in toroidal systems, Nuclear Fusion, vol.41, issue.6, p.721, 2001. ,
DOI : 10.1088/0029-5515/41/6/307
URL: http://iopscience.iop, Nuclear Fusion, vol.28, 1871. ,
Large Scale Optimization with applications " , Part 1: Optimization in inverse problems an design, IMA Volumes in Mathematics and its Applications, pp.17-36, 1997. ,
Finite electron temperature effects on interferometric and polarimetric measurements in fusion plasmas, Physics of Plasmas, vol.39, issue.10, p.102105, 2007. ,
DOI : 10.1063/1.866411
Modelling of polarimetry measurements at JET, Plasma Physics and Controlled Fusion, vol.50, issue.11, p.115009, 2008. ,
DOI : 10.1088/0741-3335/50/11/115009
Analysis of Faraday rotation in JET polarimetric measurements, Plasma Physics and Controlled Fusion, vol.53, issue.3, p.35001, 2011. ,
DOI : 10.1088/0741-3335/53/3/035001
Development of ITER 15???MA ELMy H-mode inductive scenario, Nuclear Fusion, vol.49, issue.8, p.85034, 2009. ,
DOI : 10.1088/0029-5515/49/8/085034
A new approach of equilibrium reconstruction for ITER, Nuclear Fusion, vol.51, issue.11, p.113022, 2011. ,
DOI : 10.1088/0029-5515/51/11/113022
Numerical optimization, Springer Series in Operations Research and Financial Engineering, 2006. ,
The International Series of Monographs in Physics, 2004. ,
Principles of magnetohydrodynamics: with applications to laboratory and astrophysical plasmas, 2004. ,
DOI : 10.1017/CBO9780511616945
Computational methods in plasma physics, 2010. ,
DOI : 10.1201/EBK1439810958
The Uncoupling of Boundary Integral and Finite Element Methods for Nonlinear Boundary Value Problems, Journal of Mathematical Analysis and Applications, vol.189, issue.2, pp.442-461, 1995. ,
DOI : 10.1006/jmaa.1995.1029
Modélisation de l'´ equilibre d'un plasma de tokamak, 1999. ,
Optimization with PDE constraints, Mathematical Modelling: Theory and Applications, vol.23, 2009. ,
Optimization of the viewing chord arrangement of the ITER poloidal polarimeter, Plasma Physics and Controlled Fusion, vol.50, issue.4, p.45004, 2008. ,
DOI : 10.1088/0741-3335/50/4/045004
