Correction to "Analysis and Optimization of Sleeping Mode in WiMAX via Stochastic Decomposition Techniques" [Sep 11 1630-1640]
This note is to correct the authorlist and authors affiliations of [1]. The submitted version of this paper that appeared in the September 2011 issue of the IEEE Journal on Selected Areas in Communications was incomplete. The byline and author affiliations should have appeared as in the current correction.
References
1. A. P. Azad, "Analysis and optimization of sleeping mode in WiMAX via stochastic decomposition techniques", IEEE Journal on Selected Areas in Communications, vol. 29, no. 8, pp. 1630-1640, September 2011.
