Time-Dependent Contraction Hierarchies and Approximation, Experimental Algorithms, pp.166-177, 2010. ,
DOI : 10.1007/978-3-642-13193-6_15
Finding Reliable Shortest Paths in Road Networks Under Uncertainty, Networks and Spatial Economics, vol.45, issue.2, pp.123-148, 2013. ,
DOI : 10.1007/s11067-012-9175-1
Reliable Shortest Path Problems in Stochastic Time-Dependent Networks, Journal of Intelligent Transportation Systems, vol.18, issue.2, pp.177-189, 2014. ,
DOI : 10.1016/j.tra.2011.04.009
The shortest route through a network with time-dependent internodal transit times, Journal of Mathematical Analysis and Applications, vol.14, issue.3, pp.493-498, 1966. ,
DOI : 10.1016/0022-247X(66)90009-6
Time-Dependent SHARC-Routing, Algorithms -ESA 2008, pp.332-343, 2008. ,
DOI : 10.1007/978-3-540-87744-8_28
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.541.7598
A note on two problems in connexion with graphs, Numerische Mathematik, vol.4, issue.1, pp.269-271, 1959. ,
DOI : 10.1007/BF01386390
Arriving on Time, Journal of Optimization Theory and Applications, vol.139, issue.3, pp.497-513, 2005. ,
DOI : 10.1007/s10957-005-7498-5
viaRODOS: Monitoring and Visualisation of Current Traffic Situation on Highways, Computer Information Systems and Industrial Management, pp.290-300, 2014. ,
DOI : 10.1109/TITS.2010.2074196
Learning the dynamics of arterial traffic from probe data using a dynamic bayesian network. Intelligent Transportation Systems, IEEE Transactions on, vol.13, issue.4, pp.1679-1693, 2012. ,
Probabilistic path queries in road networks, Proceedings of the 13th International Conference on Extending Database Technology, EDBT '10, pp.347-358, 2010. ,
DOI : 10.1145/1739041.1739084
Practical Route Planning Under Delay Uncertainty: Stochastic Shortest Path Queries, Robotics: Science and Systems VIII, pp.249-256, 2013. ,
DOI : 10.15607/RSS.2012.VIII.032
Adaptive least-expected time paths in stochastic, time-varying transportation and data networks. Networks, pp.35-52, 2000. ,
DOI : 10.1002/1097-0037(200101)37:1<35::aid-net4>3.0.co;2-g
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.316.2233
Optimal route planning under uncertainty, ICAPS, pp.131-141, 2006. ,
Shortest-path and minimum-delay algorithms in networks with time-dependent edge-length, Journal of the ACM, vol.37, issue.3, pp.607-625, 1990. ,
DOI : 10.1145/79147.214078
A simple and effective method for predicting travel times on freeways. Intelligent Transportation Systems, IEEE Transactions on, vol.5, issue.3, pp.200-207, 2004. ,
How to find the optimal paths in stochastic time-dependent transportation networks? In Intelligent Transportation Systems (ITSC), 2014 IEEE 17th International Conference on, pp.2348-2353, 2014. ,
Multi-cost optimal route planning under time-varying uncertainty, Proceedings of the 30th International Conference on Data Engineering (ICDE), 2014. ,
DOI : 10.1109/icde.2014.6816646
