Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, Epiciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : The article is focused on a particular aspect of classification, namely the issue of class imbalance. Imbalanced data adversely affects the recognition ability and requires proper classifier’s construction. In this work we present a case of music notation as an example of imbalanced data. Three classification algorithms - random forest, standard SVM and cost-sensitive SVM are described and tested. Feature selection based on random forest feature importance was used. Also, feature dimension reduction using PCA was studied.
https://hal.inria.fr/hal-01444503 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, January 24, 2017 - 10:41:49 AM Last modification on : Wednesday, January 25, 2017 - 1:04:04 AM Long-term archiving on: : Tuesday, April 25, 2017 - 2:05:06 PM
Wojciech Lesinski, Agnieszka Jastrzebska. Optical Music Recognition: Standard and Cost-Sensitive Learning with Imbalanced Data. 14th Computer Information Systems and Industrial Management (CISIM), Sep 2015, Warsaw, Poland. pp.601-612, ⟨10.1007/978-3-319-24369-6_51⟩. ⟨hal-01444503⟩
