Category Theoretic Semantics for Theorem Proving in Logic Programming: Embracing the Laxness
A propositional logic program P may be identified with a $P_fP_f$-coalgebra on the set of atomic propositions in the program. The corresponding $C(P_fP_f)$-coalgebra, where $C(P_fP_f)$ is the cofree comonad on $P_fP_f$, describes derivations by resolution. Using lax semantics, that correspondence may be extended to a class of first-order logic programs without existential variables. The resulting extension captures the proofs by term-matching resolution in logic programming. Refining the lax approach, we further extend it to arbitrary logic programs. We also exhibit a refinement of Bonchi and Zanasi’s saturation semantics for logic programming that complements lax semantics.
