-Median and Facility Location Problems, SIAM Journal on Computing, vol.33, issue.3, pp.544-562, 2004. ,
DOI : 10.1137/S0097539702416402
URL : https://hal.archives-ouvertes.fr/hal-00857508
Smaller core-sets for balls, Proceedings of the fourteenth annual ACM-SIAM symposium on Discrete algorithms, pp.801-802, 2003. ,
Approximate clustering via core-sets, Proceedings of the thiry-fourth annual ACM symposium on Theory of computing, pp.250-257, 2002. ,
Probabilistic approximation of metric spaces and its algorithmic applications, Proceedings of 37th Conference on Foundations of Computer Science, pp.184-193, 1996. ,
DOI : 10.1109/SFCS.1996.548477
A Constant-Factor Approximation Algorithm for the k-Median Problem, Proceedings of the thirty-first annual ACM symposium on Theory of computing, pp.1-10, 1999. ,
DOI : 10.1006/jcss.2002.1882
On Linear-Time Deterministic Algorithms for Optimization Problems in Fixed Dimension, Journal of Algorithms, vol.21, issue.3, pp.579-597, 1996. ,
DOI : 10.1006/jagm.1996.0060
Evolutionary algorithms for solving multi-objective problems, 2002. ,
DOI : 10.1007/978-1-4757-5184-0
Multi-objective optimization using evolutionary algorithms, 2001. ,
Smaller coresets for k-median and k-means clustering, Proceedings of the twenty-first annual symposium on Computational geometry, pp.126-134, 2005. ,
DOI : 10.1145/1064092.1064114
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.121.4073
Coresets for k-means and k-median clustering and their applications, pp.291-300, 2004. ,
DOI : 10.1145/1007352.1007400
-Center Problem, Mathematics of Operations Research, vol.10, issue.2, pp.180-198, 1985. ,
DOI : 10.1287/moor.10.2.180
URL : https://hal.archives-ouvertes.fr/hal-00897097
A new greedy approach for facility location problems, Proceedings of the thiry-fourth annual ACM symposium on Theory of computing , STOC '02, pp.731-740, 2002. ,
DOI : 10.1145/509907.510012
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.126.4544
On the Complexity of Some Common Geometric Location Problems, SIAM Journal on Computing, vol.13, issue.1, pp.182-196, 1984. ,
DOI : 10.1137/0213014
A k-Median Algorithm with Running Time Independent of Data Size, Machine Learning, pp.61-87, 2004. ,
DOI : 10.1023/B:MACH.0000033115.78247.f0
On the approximability of trade-offs and optimal access of Web sources, Proceedings 41st Annual Symposium on Foundations of Computer Science, pp.86-92, 2000. ,
DOI : 10.1109/SFCS.2000.892068
Approximation Algorithms for Facility Location Problems, Approximation Algorithms for Combinatorial Optimization, pp.27-32, 2000. ,
DOI : 10.1007/3-540-44436-X_4
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.105.9226
-Median Problems, Management Science, vol.29, issue.4, pp.482-497, 1983. ,
DOI : 10.1287/mnsc.29.4.482
A simple streaming algorithm for minimum enclosing balls, CCCG. Citeseer, 2006. ,
Streaming 1-center with outliers in high dimensions, CCCG, pp.83-86, 2009. ,
