Adaptive Resource Management and Scheduling for Cloud Computing ,
Towards Type-Based Optimizations in Distributed Applications Using ABS and JAVA 8 Adaptive Resource Management and Scheduling for Cloud Computing, pp.2014-103 ,
Programming and deployment of active objects with application-level scheduling, Proceedings of the 27th Annual ACM Symposium on Applied Computing, SAC '12, 2012. ,
DOI : 10.1145/2245276.2232086
ABS: A core language for abstract behavioral specification Formal Methods for Components and Objects, 2012. ,
Programming with actors in Java 8 Leveraging Applications of Formal Methods, Verification and Validation. Specialized Techniques and Applications, pp.37-53, 2014. ,
Multiprocessing the Sieve of Eratosthenes, Computer, vol.20, issue.4, pp.50-58, 1987. ,
DOI : 10.1109/MC.1987.1663535
Monitors: An operating system structuring concept, Communications of the ACM, vol.1710, pp.549-557, 1974. ,
Concurrent programming: principles and practice, 1991. ,
Analysis of the producer-consumer problem, Journal of Large-Scale Archetypes, vol.0, pp.72-92, 2002. ,
The java. util. concurrent synchronizer framework, Science of Computer Programming, vol.583, pp.293-309, 2005. ,
Java threads, 1999. ,
Using MPI: portable parallel programming with the message-passing interface, 1999. ,
OpenStream, ACM Transactions on Architecture and Code Optimization, vol.9, issue.4, p.53, 2013. ,
DOI : 10.1145/2400682.2400712
URL : https://hal.archives-ouvertes.fr/hal-00786675
DFT-Based Electronic Structure Calculations on Hybrid and Massively Parallel Computer Architectures, Bulletin, 2014. ,
Intel Cilk Plus for complex parallel algorithms: ???Enormous Fast Fourier Transforms??? (EFFT) library, Parallel Computing, vol.48, 2014. ,
DOI : 10.1016/j.parco.2015.05.004
Hybrid MPI/OpenMP Parallel Programming on Clusters of Multi-Core SMP Nodes, 2009 17th Euromicro International Conference on Parallel, Distributed and Network-based Processing, 2009. ,
DOI : 10.1109/PDP.2009.43
OpenMP: an industry standard API for shared-memory programming, IEEE Computational Science and Engineering, vol.5, issue.1, pp.46-55, 1998. ,
DOI : 10.1109/99.660313
A NOTE ON PARALLEL FINITE DIFFERENCE APPROXIMATE INVERSE PRECONDITIONING ON MULTICORE SYSTEMS USING POSIX THREADS, International Journal of Computational Methods, vol.10, issue.05, p.5, 2013. ,
DOI : 10.1142/S0219876213500321
A Library Implementation of POSIX Threads under UNIX, 1993. ,
A taxonomy of synchronous parallel machines, WASHINGTON UNIV SEATTLE DEPT OF COMPUTER SCIENCE, 1988. ,
Completing an MIMD multiprocessor taxonomy, ACM SIGARCH Computer Architecture News, vol.16, issue.3, pp.44-47, 1988. ,
DOI : 10.1145/48675.48682
Identification of common molecular subsequences, Journal of Molecular Biology, vol.147, issue.1, pp.195-197, 1981. ,
DOI : 10.1016/0022-2836(81)90087-5
ZIB Structure Prediction Pipeline: Composing a Complex Biological Workflow Through Web Services, Euro-Par 2006, pp.1148-1158, 2006. ,
DOI : 10.1007/11823285_121
The Grid: Blueprint for a New Computing Infrastructure, 1999. ,
Grid information services for distributed resource sharing, Proceedings 10th IEEE International Symposium on High Performance Distributed Computing, pp.181-184, 2001. ,
DOI : 10.1109/HPDC.2001.945188
The Physiology of the Grid, Global Grid Forum, 2002. ,
DOI : 10.1002/0470867167.ch8
Coordination languages and their significance, Communications of the ACM, vol.35, issue.2, p.96, 1992. ,
DOI : 10.1145/129630.376083
