Automata Learning through Counterexample Guided Abstraction Refinement, FM 2012: Formal Methods, volume LNCS 7436, pp.10-27, 2012. ,
DOI : 10.1007/978-3-642-32759-9_4
Improving active Mealy machine learning for protocol conformance testing, Machine Learning, pp.189-224, 2014. ,
DOI : 10.1007/s10994-013-5405-0
Synthesis of interface specifications for java classes, SIGPLAN Not, vol.40, issue.1, 2005. ,
A Model-Based Synthesis Process for Choreography Realizability Enforcement, Proc. of FASE'13, pp.37-52, 2013. ,
DOI : 10.1007/978-3-642-37057-1_4
URL : https://hal.archives-ouvertes.fr/hal-00866622
Modelland: Where do models come from? In Models@run.time, p.8378, 2014. ,
DOI : 10.1007/978-3-319-08915-7_6
Synthesis of Resilient Choreographies, Software Engineering for Resilient Systems, pp.94-108, 2013. ,
DOI : 10.1007/978-3-642-40894-6_8
URL : https://hal.archives-ouvertes.fr/hal-00866633
Automated Synthesis of Service Choreographies, IEEE Software, vol.32, issue.1, p.2015 ,
DOI : 10.1109/MS.2014.131
CHOReOSynt: enforcing choreography realizability in the future internet, Proceedings of the 22nd ACM SIGSOFT International Symposium on Foundations of Software Engineering, FSE 2014, 2014. ,
DOI : 10.1145/2635868.2661667
Distributed Enforcement of Service Choreographies, Proc. of FOCLASA'14, 2014. ,
DOI : 10.4204/EPTCS.175.2
URL : https://hal.archives-ouvertes.fr/hal-00866629
Regular Inference for State Machines Using Domains with Equality Tests, Proc. of FASE'08, p.4961, 2008. ,
DOI : 10.1007/978-3-540-78743-3_24
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.468.8833
Automatic synthesis of behavior protocols for composable web-services, Proceedings of the 7th joint meeting of the European software engineering conference and the ACM SIGSOFT symposium on The foundations of software engineering on European software engineering conference and foundations of software engineering symposium, ESEC/FSE '09, 2009. ,
DOI : 10.1145/1595696.1595719
URL : https://hal.archives-ouvertes.fr/inria-00415421
Search Computing Challenges and Directions, Objects and Databases, pp.1-5, 2010. ,
DOI : 10.1007/978-3-642-16092-9_1
URL : http://nbn-resolving.de/urn:nbn:de:bsz:352-252668
Automatically generating test cases for specification mining. Software Engineering, IEEE Transactions on, vol.38, issue.2, pp.243-257, 2012. ,
DOI : 10.1109/tse.2011.105
Modeldriven techniques to enhance architectural languages interoperability, Proc. of FASE'12, pp.26-42, 2012. ,
Software engineering in an uncertain world, Proceedings of the FSE/SDP workshop on Future of software engineering research, FoSER '10, pp.125-128, 2010. ,
DOI : 10.1145/1882362.1882389
Synthesizing intensional behavior models by graph transformation, 2009 IEEE 31st International Conference on Software Engineering, pp.430-440, 2009. ,
DOI : 10.1109/ICSE.2009.5070542
Counterexample Guided Synthesis of Monitors for Realizability Enforcement, Automated Technology for Verification and Analysis, pp.238-253, 2012. ,
DOI : 10.1007/978-3-642-33386-6_20
On the Composition and Reuse of Viewpoints across Architecture Frameworks, 2012 Joint Working IEEE/IFIP Conference on Software Architecture and European Conference on Software Architecture, pp.131-140, 2012. ,
DOI : 10.1109/WICSA-ECSA.212.21
CIGAR: Concurrent and Interleaving Goal and Activity Recognition, Proc. of AAAI'08, pp.1363-1368, 2008. ,
Test-based model generation for legacy systems, Proc. of ITC'03, pp.150-159, 2003. ,
DOI : 10.1109/test.2003.1271205
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.107.7767
Producing software by integration: challenges and research directions (keynote), Proceedings of the 2013 9th Joint Meeting on Foundations of Software Engineering, ESEC/FSE 2013, pp.2-12, 2013. ,
DOI : 10.1145/2491411.2505428
URL : https://hal.archives-ouvertes.fr/hal-00866579
Application-Layer Connector Synthesis, SFM, 2011. ,
DOI : 10.1007/978-3-642-21455-4_5
URL : https://hal.archives-ouvertes.fr/inria-00620465
Automatic synthesis of modular connectors via composition of protocol mediation patterns, 2013 35th International Conference on Software Engineering (ICSE), 2013. ,
DOI : 10.1109/ICSE.2013.6606546
Analysis of Realizability Conditions for Web Service Choreographies, Proc. of FORTE'06, pp.61-76, 2006. ,
DOI : 10.1145/322374.322380
Choreography Conformance Analysis: Asynchronous Communications and Information Alignment, Web Services and Formal Methods, pp.227-241, 2006. ,
DOI : 10.1007/11841197_15
Using genetic search for reverse engineering of parametric behavior models for performance prediction. Software Engineering, IEEE Transactions on, vol.36, issue.6, pp.865-877, 2010. ,
A Pattern-Based Approach to Development of Service Mediators for Protocol Mediation, Seventh Working IEEE/IFIP Conference on Software Architecture (WICSA 2008), pp.137-146, 2008. ,
DOI : 10.1109/WICSA.2008.13
Automatic generation of software behavioral models, Proceedings of the 13th international conference on Software engineering , ICSE '08, 2008. ,
DOI : 10.1145/1368088.1368157
Adaptation of service protocols using process algebra and on-the-fly reduction techniques. Software Engineering, IEEE Transactions on, vol.38, issue.4, pp.755-777, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00717252
Automated black-box testing of functional correctness using function approximation, Proc. of ISSTA'04, pp.143-153, 2004. ,
Preventing user errors by systematic analysis of deviations from the system task model, International Journal of Human-Computer Studies, vol.56, issue.2, pp.225-245, 2002. ,
DOI : 10.1006/ijhc.2001.0523
Tcpcompose a tcp-net based algorithm for efficient composition of web services using qualitative preferences, Service- Oriented Computing ICSOC, pp.453-467, 2008. ,
ASTRO: Supporting Composition and Execution of Web Services, ICSOC'05, pp.495-501, 2005. ,
DOI : 10.1007/11596141_39
Requirements Engineering -From System Goals to UML Models to Software Specifications, 2009. ,
Mining Temporal Specifications from Object Usage, 2009 IEEE/ACM International Conference on Automated Software Engineering, pp.295-306, 2009. ,
DOI : 10.1109/ASE.2009.30
Detecting object usage anomalies, Proceedings of the the 6th joint meeting of the European software engineering conference and the ACM SIGSOFT symposium on The foundations of software engineering , ESEC-FSE '07, pp.35-44, 2007. ,
DOI : 10.1145/1287624.1287632
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.114.4721
Exploratory Search: Beyond the Query-Response Paradigm. Synthesis Lectures on Information Concepts, Retrieval, and Services, 2009. ,
