Computation of Euclidean minima in totally definite quaternion fields - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
We describe an algorithm that allows to compute the Euclidean minimum (for the norm form) of any order of a totally definite quaternion field over a number field K of degree strictly greater than 1. Our approach is a generalization of previous work dealing with number fields. The algorithm was practically implemented when K has degree 2.
quaterminima.pdf (310.61 Ko) Télécharger le fichier
hal-01447059 , version 1 (26-01-2017)
hal-01447059 , version 2 (07-03-2017)
hal-01447059 , version 3 (14-07-2018)
  • HAL Id : hal-01447059 , version 2
Jean-Paul Cerri, Pierre Lezowski. Computation of Euclidean minima in totally definite quaternion fields. 2017. ⟨hal-01447059v2⟩
443 Consultations
238 Téléchargements
