Genotypic and phenotypic characterization of foodborne Geobacillus stearothermophilus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Food Microbiology Année : 2015
Geobacillus stearothermophilus is the main thermophilic spore former involved in flat sour spoilage of canned foods. Three typing methods were tested and applied to differentiate strains at intra-species level: panC sequence analysis, REP-PCR and M13-PCR. panC gene was highly conserved within the studied strains, suggesting a low intra-specific diversity. This was supported by REP-PCR primary assays and M13-PCR results. M13-PCR profile analysis succeeded in differentiating six closely related groups (at 79% threshold similarity) among 127 strains from a range of spoiled canned food products and from different canneries. Phenotypic traits were investigated among 20 selected strains representing groups and origins. Ranges of growth under different temperatures (from 40 °C to 70 °C), pH (from 5.0 to 6.5), NaCl concentrations (from 1 to 5%) and sporulation conditions poorly differed between strains, but wet heat resistance of spores showed a 20-fold variation between strains. Furthermore, in this study, strains that belonged to the same M13-PCR genetic group did not share phenotypic characteristics or common origin. The work emphasizes a low diversity within the G. stearothermophilus species but data from this study may contribute to a better control of G. stearothermophilus spoilage in canned food.
2014 Durand et al genotypic phenotypic characterization Geobacillus_hal.pdf (3.28 Mo) Télécharger le fichier
hal-01447933 , version 1 (25-09-2017)
Loïc Durand, Stella Planchon, Marie-Hélène Guinebretière, Frederic Carlin, Fabienne Remize. Genotypic and phenotypic characterization of foodborne Geobacillus stearothermophilus. Food Microbiology, 2015, 45, pp.103-110. ⟨10.1016/j.fm.2014.01.015⟩. ⟨hal-01447933⟩
295 Consultations
905 Téléchargements
