USING INTERNAL MySQL/InnoDB B-TREE INDEX NAVIGATION FOR DATA HIDING - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Peter Fruhwirt
  • Fonction : Auteur
Peter Kieseberg
  • Fonction : Auteur
Edgar Weippl
  • Fonction : Auteur
Large databases provide interesting environments for hiding data. These databases store massive amounts of diverse data, they are riddled with internal mechanisms and data pools for enhancing performance, and they contain complex optimization routines that constantly change portions of the underlying file environments. The databases are valuable targets for attackers who wish to manipulate search results or hide traces of data access or modification. Despite its importance, research on data hiding in databases is relatively sparse. This chapter describes several data hiding techniques in MySQL and demonstrates the impact of data deletion on forensic analysis.
978-3-319-24123-4_11_Chapter.pdf (381.98 Ko) Télécharger le fichier
hal-01449058 , version 1 (30-01-2017)
Paternité
Peter Fruhwirt, Peter Kieseberg, Edgar Weippl. USING INTERNAL MySQL/InnoDB B-TREE INDEX NAVIGATION FOR DATA HIDING. 11th IFIP International Conference on Digital Forensics (DF), Jan 2015, Orlando, FL, United States. pp.179-194, ⟨10.1007/978-3-319-24123-4_11⟩. ⟨hal-01449058⟩
90 Consultations
514 Téléchargements
