Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Conference papers
Using a Mobile Phone as a 2D Virtual Tracing Tool: Static Peephole vs. Magic Lens
Abstract : Traditional sketching aids rely on the physical production of templates or stencils which is particularly problematic in the case of larger formats. One possible solution is 2D virtual tracing using a virtual template to create a physical sketch. This paper evaluates a mobile phone as a 2D virtual tracing tool by comparing three tracing methods: (i) a traditional tracing method with a printed template, (ii) a virtual tracing method Static Peephole (SP) in which the virtual template is manually adjusted to a physical contour by drag and pinch gestures, and (iii) a virtual tracing method augmented reality Magic Lens (ML) in which template is projected on the physical object such as paper hence navigation is possible through physical movement of the mobile device. The results show that it is possible to use mobile phones for virtual tracing, however, ML only achieved comparable performance to SP mode and traditional methods continued to be quicker and preferred by users.
Document type :
Conference papers
Complete list of metadata
Cited literature [18 references]  Display  Hide  Download
https://hal.inria.fr/hal-01449441
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Monday, January 30, 2017 - 2:40:41 PM
Last modification on : Tuesday, May 25, 2021 - 12:36:02 PM
File
430485_1_En_22_Chapter.pdf
Identifiers
Citation
Klen Čopič Pucihar, Matjaž Kljun, Paul Coulton. Using a Mobile Phone as a 2D Virtual Tracing Tool: Static Peephole vs. Magic Lens. 12th IFIP International Conference on Human Choice and Computers (HCC), Sep 2016, Salford, United Kingdom. pp.277-288, ⟨10.1007/978-3-319-44805-3_22⟩. ⟨hal-01449441⟩
Share
Metrics
Record views
40
Files downloads
96
