New interface
Conference papers
Research on Recognition Algorithm of Track Substructure Defects Based on Vehicle Dynamic Responses
Abstract : Track stiffness abrupt change caused by track substructure defects can lead to rather large dynamic irregularity when the train goes through it. Thus the dynamic action between wheel and rail is increasing, which will influence the safety and comfort of the train. In this paper, the dynamic responses of vehicle and track are analyzed based on vehicle track coupling model in which two kinds of defects of track substructure are simulated. To reduce the maintenance cost, a recognition algorithm of track substructure defects using vehicle dynamic responses is proposed based on Support Vector Machines. Finally, a case has been studied based on the algorithm proposed in this paper, and the simulation results show that the method is effective to recognize the track substructure defects such as unsupported sleepers, loosened fasteners, and the accuracy of recognition can be reached to 90%.
Document type :
Conference papers
Complete list of metadata
Cited literature [9 references]  Display  Hide  Download
https://hal.inria.fr/hal-01449766
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Monday, January 30, 2017 - 4:45:51 PM
Last modification on : Thursday, March 5, 2020 - 4:45:17 PM
File
978-3-642-41263-9_65_Chapter.p...
Identifiers
Citation
Hongmei Shi. Research on Recognition Algorithm of Track Substructure Defects Based on Vehicle Dynamic Responses. 20th Advances in Production Management Systems (APMS), Sep 2013, State College, PA, United States. pp.525-532, ⟨10.1007/978-3-642-41263-9_65⟩. ⟨hal-01449766⟩
Share
Metrics
Record views
41
Files downloads
75
