Sparse Supernodal Solver Using Block Low-Rank Compression - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2017
This paper presents two approaches using a Block Low-Rank (BLR) compression technique to reduce the memory footprint and/or the time-to-solution of the sparse supernodal solver PaStiX. This flat, non-hierarchical, compression method allows to take advantage of the low-rank property of the blocks appearing during the factorization of sparse linear systems, which come from the discretization of partial differential equations. The first approach, called Minimal Memory, illustrates the maximum memory gain that can be obtained with the BLR compression method, while the second approach, called Just-In-Time, mainly focuses on reducing the computational complexity and thus the time-to-solution. Singular Value Decomposition (SVD) and Rank-Revealing QR (RRQR), as compression kernels, are both compared in terms of factorization time, memory consumption, as well as numerical properties. Experiments on a single node with 24 threads and 128 GB of memory are presented on a set of matrices from real-life problems. We demonstrate a memory footprint reduction of up to 4.4 times using the Minimal Memory strategy and a computational time speedup of up to 3.3 times with the Just-In-Time strategy.
RR-9022.pdf (1020.02 Ko) Télécharger le fichier
hal-01450732 , version 1 (31-01-2017)
hal-01450732 , version 2 (01-02-2017)
hal-01450732 , version 3 (01-02-2017)
  • HAL Id : hal-01450732 , version 1
Grégoire Pichon, Eric Darve, Mathieu Faverge, Pierre Ramet, Jean Roman. Sparse Supernodal Solver Using Block Low-Rank Compression. [Research Report] RR-9022, Inria Bordeaux Sud-Ouest. 2017, pp.24. ⟨hal-01450732v1⟩
417 Consultations
450 Téléchargements
