An application of Lagrangean decomposition to the capacitated multi-item lot sizing proble, Computers & Operations Research, vol.20, issue.4, pp.409-420, 1993. ,
DOI : 10.1016/0305-0548(93)90085-W
A heuristic solution procedure for the multi-item, single-level, limited capacity, lot-sizing problem, Journal of Operations Management, vol.2, issue.1, pp.23-40, 1981. ,
DOI : 10.1016/0272-6963(81)90033-4
Multilevel capacitated lotsizing complexity and LP-based heuristics, European Journal of Operational Research, vol.53, issue.2, pp.131-148, 1991. ,
DOI : 10.1016/0377-2217(91)90130-N
Multi-Item Lot Size Scheduling by Heuristic Part I: With Fixed Resources, Management Science, vol.21, issue.10, pp.1186-1193, 1975. ,
DOI : 10.1287/mnsc.21.10.1086
Multi-Item Lot Size Scheduling by Heuristic Part II: With Variable Resources, Management Science, vol.21, issue.10, pp.1194-1203, 1975. ,
DOI : 10.1287/mnsc.21.10.1194
Lagrangian Relaxation for Multi-Item Capacitated Lot Sizing Problem, AIIE Trans, vol.17, pp.308-313, 1985. ,
DOI : 10.1080/03155986.1991.11732175
Lagrangian heuristics for the capacitated multi-item lot-sizing problem with backordering, International Journal of Production Economics, vol.34, issue.1, pp.1-15, 1994. ,
DOI : 10.1016/0925-5273(94)90042-6
The Capacitated Lot Sizing Problem with Setup Carryover, IIE Transactions, vol.31, pp.173-181, 1999. ,
A Lagrangean Relaxation Approach for Very-Large-Scale Capacitated Lot-Sizing, Management Science, vol.38, issue.9, pp.1329-1340, 1992. ,
DOI : 10.1287/mnsc.38.9.1329
Capacitated Lot Sizing with Setup Times, Management Science, vol.35, issue.3, pp.353-366, 1989. ,
DOI : 10.1287/mnsc.35.3.353
An Algorithm for the Dynamic Lot-Size Problem with Time-Varying Production Capacity Constraints, Management Science, vol.24, issue.16, pp.1710-1720, 1978. ,
DOI : 10.1287/mnsc.24.16.1710
A framework for modelling setup carryover in the capacitated lot sizing problem, International Journal of Production Research, vol.11, issue.7, pp.1973-1988, 1995. ,
Capacitated Lot Sizing with Linked Production Quantities for Adjacent Periods, Operations Research '93, pp.212-215, 1994. ,
