A genetic algorithm for the simultaneous delivery and pickup problems with time window, Computers & Industrial Engineering, vol.62, issue.1, pp.84-95, 2012. ,
DOI : 10.1016/j.cie.2011.08.018
A branch-and-price algorithm for a simultaneous pickup and delivery problem. Quantitative Approaches to Distribution Logistics and Supply Chain Management, pp.249-267, 2003. ,
An improved differential evolution algorithm for vehicle routing problem with simultaneous pickups and deliveries and time windows, Engineering Applications of Artificial Intelligence, vol.23, issue.2, pp.188-195, 2010. ,
Multi-ant colonies algorithms for the VRPSPDTW, 2011 International Conference on Communications, Computing and Control Applications (CCCA), pp.3-5, 2011. ,
DOI : 10.1109/CCCA.2011.6031488
Algorithms for the Vehicle Routing and Scheduling Problems with Time Window Constraints, Operations Research, vol.35, issue.2, pp.254-265, 1987. ,
DOI : 10.1287/opre.35.2.254
A parallel heuristic for the Vehicle Routing Problem with Simultaneous Pickup and Delivery, Computers & Operations Research, vol.37, issue.11, pp.1899-1911, 2010. ,
DOI : 10.1016/j.cor.2009.10.011
The multiple vehicle routing problem with simultaneous delivery and pick-up points, Transportation Research Part A: General, vol.23, issue.5, pp.377-3860191, 1989. ,
DOI : 10.1016/0191-2607(89)90085-X
A branch-and-price approach to the vehicle routing problem with simultaneous distribution and collection, Transportation Science, vol.40, issue.2, pp.235-247, 2006. ,
Branch-and-cut with lazy separation for the vehicle routing problem with simultaneous pickup and delivery, Operations Research Letters, vol.39, issue.5, pp.338-341, 2011. ,
DOI : 10.1016/j.orl.2011.06.012
A Branch-and-Cut Approach to the Vehicle Routing Problem with Simultaneous Delivery and Pick-up, Operations Research Proceedings, pp.301-306, 2008. ,
DOI : 10.1007/978-3-642-00142-0_49
Vehicle routing and reverse logistics: The vehicle routing problem with simultaneous delivery and pick-up, OR Spektrum, vol.23, issue.1, pp.79-96, 2001. ,
DOI : 10.1007/PL00013346
A unified heuristic for a large class of Vehicle Routing Problems with Backhauls, European Journal of Operational Research, vol.171, issue.3, pp.750-775, 2006. ,
DOI : 10.1016/j.ejor.2004.09.004
GENVNS-TS-CL-PR: A heuristic approach for solving the vehicle routing problem with simultaneous pickup and delivery, Electronic Notes in Discrete Mathematics, vol.39, pp.217-224, 2012. ,
DOI : 10.1016/j.endm.2012.10.029
A tabu search algorithm for the vehicle routing problem with simultaneous pick-up and delivery service, Computers & Operations Research, vol.33, issue.3, pp.595-619, 2006. ,
DOI : 10.1016/j.cor.2004.07.009
A local search metaheuristic algorithm for the vehicle routing problem with simultaneous pick-ups and deliveries, Expert Systems with Applications, vol.38, issue.3, pp.2717-2726, 2011. ,
DOI : 10.1016/j.eswa.2010.08.061
An ant colony system (ACS) for vehicle routing problem with simultaneous delivery and pickup, Computers & Operations Research, vol.36, issue.12, pp.3215-3223, 2009. ,
DOI : 10.1016/j.cor.2009.02.017
A new saving-based ant algorithm for the Vehicle Routing Problem with Simultaneous Pickup and Delivery, Expert Systems with Applications, vol.37, issue.10, pp.6809-6817, 2010. ,
DOI : 10.1016/j.eswa.2010.03.045
A genetic algorithm based approach to vehicle routing problem with simultaneous pick-up and deliveries, Computers & Industrial Engineering, 2011. ,
A particle swarm optimization for the vehicle routing problem with simultaneous pickup and delivery, Computers & Operations Research, vol.36, issue.5, pp.1693-1702, 2009. ,
DOI : 10.1016/j.cor.2008.04.003
An ILS Based Heuristic for the Vehicle Routing Problem with Simultaneous Pickup and Delivery and Time Limit, Evolutionary Computation in Combinatorial Optimization, pp.135-146, 2008. ,
DOI : 10.1007/978-3-540-78604-7_12
Parallel simulated annealing for the vehicle routing problem with time windows, Proceedings 10th Euromicro Workshop on Parallel, Distributed and Network-based Processing, pp.376-383, 1987. ,
DOI : 10.1109/EMPDP.2002.994313
