A Model Based Continuous Improvement Methodology for Sustainable Manufacturing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper proposes a model based continuous improvement methodology to support efforts to achieve sustainable manufacturing, i.e., to increase efficiency and reduce environmental impact of manufacturing systems. Past efforts have provided guidance at a high level or with a focus on products. This paper focuses on supporting efforts for manufacturing, in particular, at the factory level. A framework is proposed to support the methodology by facilitating application of optimization and simulation models for sustainable manufacturing.
978-3-642-41266-0_33_Chapter.pdf (1.01 Mo) Télécharger le fichier
hal-01452124 , version 1 (01-02-2017)
Paternité
Sanjay Jain, Gordon Shao, Alexander Brodsky, Frank Riddick. A Model Based Continuous Improvement Methodology for Sustainable Manufacturing. 20th Advances in Production Management Systems (APMS), Sep 2013, State College, PA, United States. pp.268-277, ⟨10.1007/978-3-642-41266-0_33⟩. ⟨hal-01452124⟩
84 Consultations
126 Téléchargements
