A Study on the Effect of Inspection Time on Defect Detection in Visual Inspection - Archive ouverte HAL Access content directly
Conference Papers Year : 2013
(1) , (2) , (1)
1
2
Ryosuke Nakajima
  • Function : Author
  • PersonId : 996293
Keisuke Shida
  • Function : Author
  • PersonId : 1000041
Toshiyuki Matsumoto
  • Function : Author
  • PersonId : 996296
In order to consider the visual inspection utilizing the peripheral vision, this paper examines the inspection times that affect defect detection. The fixation duration and the distance between defect and the fixation point are experimental factors in determining the inspection time. As the result, in case of a large sized defect, the detection rate is high regardless of the fixation duration and the distance between the defect and the fixation point. In case of a small sized defect, when the fixation duration is longer and the distance between the defect and the fixation point is closer, the defect detection rate is higher. Moreover, as the result of conducting multiple linear regression analysis about the experiment factors, it is obtained that judging from standardized partial regression coefficient of factors, higher defect size, less the distance between defect and the fixation point, the higher fixation duration, is proved to improve the defect detection.
978-3-642-41266-0_4_Chapter.pdf (644.1 Ko) Télécharger le fichier
Dates and versions
hal-01452141 , version 1 (01-02-2017)
Attribution - CC BY 4.0
Identifiers
Cite
Ryosuke Nakajima, Keisuke Shida, Toshiyuki Matsumoto. A Study on the Effect of Inspection Time on Defect Detection in Visual Inspection. 20th Advances in Production Management Systems (APMS), Sep 2013, State College, PA, United States. pp.29-39, ⟨10.1007/978-3-642-41266-0_4⟩. ⟨hal-01452141⟩
57 View
550 Download
Share
