Analysis of Linear Convergence of a (1 + 1)-ES with Augmented Lagrangian Constraint Handling, Proceedings of the 2016 on Genetic and Evolutionary Computation Conference, GECCO '16, pp.213-220, 2016. ,
DOI : 10.1145/2908812.2908901
URL : https://hal.archives-ouvertes.fr/hal-01318807
Augmented Lagrangian Constraint Handling for CMA-ES ??? Case of a Single Linear Constraint, Parallel Problem Solving from Nature, pp.181-191, 2016. ,
DOI : 10.1007/978-3-319-45823-6_17
URL : https://hal.archives-ouvertes.fr/hal-01390386
Convergence results for the <mml:math altimg="si1.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mo stretchy="false">(</mml:mo><mml:mn>1</mml:mn><mml:mo>,</mml:mo><mml:mi>??</mml:mi><mml:mo stretchy="false">)</mml:mo></mml:math>-SA-ES using the theory of <mml:math altimg="si2.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mi>??</mml:mi></mml:math>-irreducible Markov chains, Theoretical Computer Science, vol.334, issue.1-3, pp.35-69, 2005. ,
DOI : 10.1016/j.tcs.2004.11.017
Linear Convergence of Comparison-based Step-size Adaptive Randomized Search via Stability of Markov Chains, SIAM Journal on Optimization, vol.26, issue.3, pp.1589-1624, 2016. ,
DOI : 10.1137/140984038
URL : https://hal.archives-ouvertes.fr/hal-00877160
Global convergence for evolution strategies in spherical problems: some simple proofs and difficulties, Theoretical Computer Science, vol.306, issue.1-3, pp.1-3269, 2003. ,
DOI : 10.1016/S0304-3975(03)00284-6
A genetic algorithm based augmented Lagrangian method for constrained optimization, Computational Optimization and Applications, vol.52, issue.1, pp.869-902, 2012. ,
DOI : 10.1007/s10589-012-9468-9
The CMA Evolution Strategy: A Tutorial, 2016. ,
DOI : 10.1007/3-540-32494-1_4
URL : https://hal.archives-ouvertes.fr/hal-01297037
Completely Derandomized Self-Adaptation in Evolution Strategies, Evolutionary Computation, vol.9, issue.2, pp.159-195, 2001. ,
DOI : 10.1016/0004-3702(95)00124-7
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.13.7462
Multiplier and gradient methods, Journal of Optimization Theory and Applications, vol.4, issue.5, pp.303-320, 1969. ,
DOI : 10.1007/BF00927673
Markov Chains and Stochastic Stability, 1993. ,
Numerical Optimization, 2006. ,
DOI : 10.1007/b98874
A Method for Nonlinear Constraints in Minimization Problems, pp.283-298, 1969. ,
Coevolutionary augmented Lagrangian methods for constrained optimization, IEEE Transactions on Evolutionary Computation, vol.4, issue.2, pp.114-124, 2000. ,
DOI : 10.1109/4235.850652
