CMOS Implementation of Threshold Gates with Hysteresis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Farhad A. Parsan
  • Fonction : Auteur
  • PersonId : 1000364
Scott C. Smith
  • Fonction : Auteur
  • PersonId : 1000365
NULL Convention Logic (NCL) is one of the mainstream asynchronous logic design paradigms. NCL circuits use threshold gates with hysteresis. In this chapter, the transistor-level CMOS design of NCL gates is investigated, and various gate styles are introduced and compared to each other. In addition, a novel approach to design static NCL gates is introduced. The new approach is based on integrating each pair of pull-up and pull-down transistor networks into one composite transistor network. The new static gates are then compared to the original ones in terms of delay, area, and energy consumption. It will be shown that the new gate style is significantly faster with negligible area and energy overhead.
978-3-642-45073-0_11_Chapter.pdf (352.08 Ko) Télécharger le fichier
hal-01456957 , version 1 (06-02-2017)
Paternité
Farhad A. Parsan, Scott C. Smith. CMOS Implementation of Threshold Gates with Hysteresis. 20th International Conference on Very Large Scale Integration (VLSI-SoC), Aug 2012, Santa Cruz, CA, United States. pp.196-216, ⟨10.1007/978-3-642-45073-0_11⟩. ⟨hal-01456957⟩
78 Consultations
425 Téléchargements
