and Yun Pan Spatially-Varying Image Warping: Evaluations and VLSI Implementations, p.64 ,
Application-Specific Processor with Sub-V T Memories for Compressed Sensing, p.88 ,
125 Zhibin Xiao and Bevan Baas Fault-Tolerant Techniques to Manage Yield and Power Constraints in Network-on-Chip Interconnections, p.144 ,
Carro On the Automatic Generation of Software-Based Self-Test Programs for Functional Test and Diagnosis of VLIW Processors, p.162 ,
Table of Contents SEU-Aware Low-Power Memories Using a Multiple Supply Voltage Array Architecture ,
Smith Simulation and Experimental Characterization of a Unified Memory Device with Two Floating, p.217 ,
