RainPortal – A Web Portal for Providing Climate Change Related Precipitation Data Using SUDPLAN Services - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
RainPortal (http://sudplan.ait.ac.at/RainPortalServer) is a web portal that has three main targets: 1) Provide access to scientifically sound data related to some key climate change aspects in Europe, 2) Provide concrete data about climate change related local precipitation changes by using climate model output and 3) Easy usage and incorporation of the provided information into existing planning workflows.
978-3-642-41151-9_32_Chapter.pdf (415.71 Ko) Télécharger le fichier
hal-01457464 , version 1 (06-02-2017)
Paternité
Peter Kutschera, Jonas Olsson, Lars Gidhagen. RainPortal – A Web Portal for Providing Climate Change Related Precipitation Data Using SUDPLAN Services. 10th International Symposium on Environmental Software Systems (ISESS), Oct 2013, Neusiedl am See, Austria. pp.336-344, ⟨10.1007/978-3-642-41151-9_32⟩. ⟨hal-01457464⟩
50 Consultations
105 Téléchargements
