An Information System Supporting WFD Reporting - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thorsten Hell
  • Fonction : Auteur
  • PersonId : 1000459
Sascha Schlobinski
  • Fonction : Auteur
  • PersonId : 983236
Ralf Denzer
  • Fonction : Auteur
  • PersonId : 983196
Reiner Güttler
  • Fonction : Auteur
  • PersonId : 1000461
The EU Water Framework Directive (WFD) defines the quality goals for European water bodies until 2027. Water bodies are managed on very different governmental levels in the member states. Due to the federal system, Germany has a complex structure of responsibilities regarding the management and maintenance of water bodies in Europe.The paper will present a highly integrated information system to support water body management in the context of the WFD. The system was designed and developed for the German federal state Mecklenburg-Vorpommern. The objective was to provide a state-wide information platform accessible through an environmental information system (EIS) for all activities related to the water body management, including the maintenance of the water body network itself, managing related information regarding statistics, agriculture and environmental protection, as well as water body quality like chemical and biological status.This EIS integrates disparate data sources from a large number of individual providers through standardized services. Moreover, the EIS provides a homogenous view on very different data regarding their topic, content, structure and spatial reference and supports all WFD reporting related workflows.
978-3-642-41151-9_38_Chapter.pdf (1.11 Mo) Télécharger le fichier
hal-01457470 , version 1 (06-02-2017)
Paternité
Thorsten Hell, Eckhard Kohlhas, Sascha Schlobinski, Ralf Denzer, Reiner Güttler. An Information System Supporting WFD Reporting. 10th International Symposium on Environmental Software Systems (ISESS), Oct 2013, Neusiedl am See, Austria. pp.403-413, ⟨10.1007/978-3-642-41151-9_38⟩. ⟨hal-01457470⟩
323 Consultations
111 Téléchargements
