MOLECULAR MECHANISM OF PHOTOSIGNALING BY ARCHAEAL SENSORY RHODOPSINS, Annual Review of Biophysics and Biomolecular Structure, vol.26, issue.1, pp.223-58, 1997. ,
DOI : 10.1146/annurev.biophys.26.1.223
The Mechanisms of HAMP-Mediated Signaling in Transmembrane Receptors, Structure, vol.19, issue.3, pp.378-85, 2011. ,
DOI : 10.1016/j.str.2011.01.006
HAMP Domain Signal Relay Mechanism in a Sensory Rhodopsin-Transducer Complex, Journal of Biological Chemistry, vol.287, issue.25, pp.21316-21341, 2012. ,
DOI : 10.1074/jbc.M112.344622
Physiological Sites of Deamidation and Methyl Esterification in Sensory Transducers of Halobacterium salinarum, Journal of Molecular Biology, vol.380, issue.2, pp.285-302, 2008. ,
DOI : 10.1016/j.jmb.2008.04.063
Structural insights into the early steps of receptor-transducer signal transfer in archaeal phototaxis, The EMBO Journal, vol.20, issue.19, pp.5312-5321, 2001. ,
DOI : 10.1093/emboj/20.19.5312
Role of the HAMP Domain Region of Sensory Rhodopsin Transducers in Signal Transduction, Biochemistry, vol.50, issue.4, pp.574-580, 2010. ,
DOI : 10.1021/bi101032a
URL : https://hal.archives-ouvertes.fr/hal-00784550
Structure of Concatenated HAMP Domains Provides a Mechanism for Signal Transduction, Structure, vol.18, issue.4, pp.436-484, 2010. ,
DOI : 10.1016/j.str.2010.01.013
Time-resolved detection of transient movement of helix F in spin-labelled pharaonis sensory rhodopsin II, Journal of Molecular Biology, vol.301, issue.4, pp.881-91, 2000. ,
DOI : 10.1006/jmbi.2000.4008
The Cytoplasmic Membrane-proximal Domain of the HtrII Transducer Interacts with the E-F Loop of Photoactivated Natronomonas pharaonis Sensory Rhodopsin II, Journal of Biological Chemistry, vol.279, issue.41, pp.42970-42976, 2004. ,
DOI : 10.1074/jbc.M406504200
Probing the Sensory Rhodopsin II Binding Domain of its Cognate Transducer by Calorimetry and Electrophysiology, Journal of Molecular Biology, vol.330, issue.5, pp.1203-1213, 2003. ,
DOI : 10.1016/S0022-2836(03)00656-9
Molecular basis of transmembrane signalling by sensory rhodopsin II???transducer complex, Nature, vol.50, issue.6906, pp.484-491, 2002. ,
DOI : 10.1038/23512
Development of the signal in sensory rhodopsin and its transfer to the cognate transducer, Nature, vol.54, issue.7080, pp.115-124, 2006. ,
DOI : 10.1038/nature04520
Structural basis of glutamate recognition by a dimeric metabotropic glutamate receptor, Nature, vol.407, pp.971-978, 2000. ,
Active State of Sensory Rhodopsin II: Structural Determinants for Signal Transfer and Proton Pumping, Journal of Molecular Biology, vol.412, issue.4, pp.591-600, 2011. ,
DOI : 10.1016/j.jmb.2011.07.022
URL : https://hal.archives-ouvertes.fr/hal-00766090
X-ray structure of sensory rhodopsin II at 2.1-A resolution, Proc. Natl. Acad. Sci. USA 98, pp.10131-10137, 2001. ,
DOI : 10.1073/pnas.181203898
Crystal Structure of Sensory Rhodopsin II at 2.4 Angstroms: Insights into Color Tuning and Transducer Interaction, Science, vol.293, issue.5534, pp.1499-503, 2001. ,
DOI : 10.1126/science.1062977
Sensory rhodopsin II and bacteriorhodopsin: Light activated helix F movement, Photochemical & Photobiological Sciences, vol.3, issue.6, p.543, 2004. ,
DOI : 10.1039/b402656j
URL : http://hdl.handle.net/11858/00-001M-0000-0014-0B53-C
41811 | DOI: 10 Mechanism divergence in microbial rhodopsins, Biochim. Biophys. Acta - Bioenerg, vol.7, issue.1837, pp.546-552, 1038. ,
Molecular and evolutionary aspects of microbial sensory rhodopsins, Biochimica et Biophysica Acta (BBA) - Bioenergetics, vol.1837, issue.5, pp.562-577, 2014. ,
DOI : 10.1016/j.bbabio.2013.05.005
Transmembrane signal transduction in archaeal phototaxis: The sensory rhodopsin II-transducer complex studied by electron paramagnetic resonance spectroscopy, European Journal of Cell Biology, vol.90, issue.9, pp.731-740, 2011. ,
DOI : 10.1016/j.ejcb.2011.04.013
Constitutive signaling by the phototaxis receptor sensory rhodopsin II from disruption of its protonated Schiff base-Asp-73 interhelical salt bridge, Proc. Natl. Acad. Sci. USA 94, pp.4960-4965, 1997. ,
DOI : 10.1073/pnas.94.10.4960
Early Structural Rearrangements in the Photocycle of an Integral Membrane Sensory Receptor, Structure, vol.10, issue.4, pp.473-482, 2002. ,
DOI : 10.1016/S0969-2126(02)00736-0
The HAMP Domain Structure Implies Helix Rotation in Transmembrane Signaling, Cell, vol.126, issue.5, pp.929-969, 2006. ,
DOI : 10.1016/j.cell.2006.06.058
Molecular modeling of the HAMP domain of sensory rhodopsin II transducer from Natronomonas pharaonis, BIOPHYSICS, vol.6, pp.27-36, 2010. ,
DOI : 10.2142/biophysics.6.27
Complex Formation and Light Activation in Membrane-Embedded Sensory Rhodopsin II as Seen by Solid-State NMR Spectroscopy, Structure, vol.18, issue.3, pp.293-300, 2010. ,
DOI : 10.1016/j.str.2010.01.011
The primary structure of sensory rhodopsin II: a member of an additional retinal protein subgroup is coexpressed with its transducer, the halobacterial transducer of rhodopsin II., Proc. Natl. Acad. Sci. USA 92, pp.3036-3076, 1995. ,
DOI : 10.1073/pnas.92.7.3036
Structural basis for sensory rhodopsin function, Biochimica et Biophysica Acta (BBA) - Biomembranes, vol.1565, issue.2, pp.196-205, 2002. ,
DOI : 10.1016/S0005-2736(02)00569-2
Large Amplitude Elastic Motions in Proteins from a Single-Parameter, Atomic Analysis, Physical Review Letters, vol.77, issue.9, pp.1905-1908, 1996. ,
DOI : 10.1103/PhysRevLett.77.1905
Building-block approach for determining low-frequency normal modes of macromolecules, Proteins: Structure, Function, and Genetics, vol.77, issue.1, pp.1-7, 2000. ,
DOI : 10.1002/1097-0134(20001001)41:1<1::AID-PROT10>3.0.CO;2-P
CHARMM-GUI Input Generator for NAMD, GROMACS, AMBER, OpenMM, and CHARMM/OpenMM Simulations Using the CHARMM36 Additive Force Field, Journal of Chemical Theory and Computation, vol.12, issue.1, pp.405-413, 2016. ,
DOI : 10.1021/acs.jctc.5b00935
Automated Builder and Database of Protein/Membrane Complexes for Molecular Dynamics Simulations, PLoS ONE, vol.26, issue.9, p.880, 2007. ,
DOI : 10.1371/journal.pone.0000880.s001
GROMACS: High performance molecular simulations through multi-level parallelism from laptops to supercomputers, SoftwareX, vol.1, issue.2, pp.19-25, 2015. ,
DOI : 10.1016/j.softx.2015.06.001
Structural Analysis of a HAMP Domain: THE LINKER REGION OF THE PHOTOTRANSDUCER IN COMPLEX WITH SENSORY RHODOPSIN II, Journal of Biological Chemistry, vol.280, issue.46, pp.38767-38775, 2005. ,
DOI : 10.1074/jbc.M509391200
Pharaonis Phoborhodopsin Binds to its Cognate Truncated Transducer Even in the Presence of a Detergent with a 1:1 Stoichiometry??, Photochemistry and Photobiology, vol.268, issue.3, pp.489-94, 2001. ,
DOI : 10.1562/0031-8655(2001)074<0489:PPBTIC>2.0.CO;2
Interaction of Natronobacterium pharaonis Phoborhodopsin (Sensory Rhodopsin II) with its Cognate Transducer Probed by Increase in the Thermal Stability??, Photochemistry and Photobiology, vol.31, issue.5, pp.511-517, 2003. ,
DOI : 10.1562/0031-8655(2003)078<0511:IONPPS>2.0.CO;2
Salt-driven Equilibrium between Two Conformations in the HAMP Domain from Natronomonas pharaonis: THE LANGUAGE OF SIGNAL TRANSFER?, Journal of Biological Chemistry, vol.283, issue.42, pp.28691-28701, 2008. ,
DOI : 10.1074/jbc.M801931200
Signaling and Adaptation Modulate the Dynamics of the Photosensoric Complex of Natronomonas pharaonis, PLOS Computational Biology, vol.83, issue.10, p.1004561, 2015. ,
DOI : 10.1371/journal.pcbi.1004561.s019
Comparative Simulations of the Ground State and the M-Intermediate State of the Sensory Rhodopsin II???Transducer Complex with a HAMP Domain Model, Biochemistry, vol.51, issue.30, pp.5958-5966, 2012. ,
DOI : 10.1021/bi300696b
Cys-Scanning Disulfide Crosslinking and Bayesian Modeling Probe the Transmembrane Signaling Mechanism of the Histidine Kinase, PhoQ, Structure, vol.22, issue.9, pp.1239-51, 2014. ,
DOI : 10.1016/j.str.2014.04.019
Transmembrane polar interactions are required for signaling in the Escherichia coli sensor kinase PhoQ, Proc. Natl. Acad. Sci. USA, pp.8141-8147, 2010. ,
DOI : 10.1073/pnas.1003166107
Regulated unfolding: a basic principle of intraprotein signaling in modular proteins, Trends in Biochemical Sciences, vol.38, issue.11, pp.538-583, 2013. ,
DOI : 10.1016/j.tibs.2013.08.005
Signaling and sensory adaptation in Escherichia coli chemoreceptors: 2015 update, Trends in Microbiology, vol.23, issue.5, pp.257-266, 2015. ,
DOI : 10.1016/j.tim.2015.03.003
Crystallizing membrane proteins using lipidic mesophases, Nature Protocols, vol.83, issue.5, pp.706-737, 2009. ,
DOI : 10.1038/nprot.2009.31
URL : http://www.ncbi.nlm.nih.gov/pmc/articles/PMC2732203
X-ray-Radiation-Induced Changes in Bacteriorhodopsin Structure, Journal of Molecular Biology, vol.409, issue.5, pp.813-838, 2011. ,
DOI : 10.1016/j.jmb.2011.04.038
The integration of macromolecular diffraction data, Acta Crystallographica Section D Biological Crystallography, vol.62, issue.1, pp.48-57, 2006. ,
DOI : 10.1107/S0907444905039107
Scaling and assessment of data quality, Acta Crystallographica Section D Biological Crystallography, vol.62, issue.1, pp.72-82, 2006. ,
DOI : 10.1107/S0907444905036693
: an Automated Program for Molecular Replacement, Journal of Applied Crystallography, vol.30, issue.6, pp.1022-1025, 1997. ,
DOI : 10.1107/S0021889897006766
: a comprehensive Python-based system for macromolecular structure solution, Acta Crystallographica Section D Biological Crystallography, vol.64, issue.2, pp.213-234, 2010. ,
DOI : 10.1107/S0907444909052925
URL : http://www.ncbi.nlm.nih.gov/pmc/articles/PMC2815670
A soluble mutant of the transmembrane receptor Af1503 features strong changes in coiled-coil periodicity, Journal of Structural Biology, vol.186, issue.3, pp.357-366, 2014. ,
DOI : 10.1016/j.jsb.2014.02.008
Practical modeling of molecular systems with symmetries, Journal of Computational Chemistry, vol.375, issue.9, pp.1799-1814, 2010. ,
DOI : 10.1002/jcc.21434
URL : https://hal.archives-ouvertes.fr/hal-00748028
The PyMOL Molecular Graphics System, Version 1.2r3pre ,
