A Long-Range Self-similarity Approach to Segmenting DJ Mixed Music Streams - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Tim Scarfe
  • Fonction : Auteur
  • PersonId : 1000608
Wouter M. Koolen
  • Fonction : Auteur
  • PersonId : 1000609
Yuri Kalnishkan
  • Fonction : Auteur
  • PersonId : 1000610
In this paper we describe an unsupervised, deterministic algorithm for segmenting DJ-mixed Electronic Dance Music streams (for example; podcasts, radio shows, live events) into their respective tracks. We attempt to reconstruct boundaries as close as possible to what a human domain expert would engender. The goal of DJ-mixing is to render track boundaries effectively invisible from the standpoint of human perception which makes the problem difficult.We use Dynamic Programming (DP) to optimally segment a cost matrix derived from a similarity matrix. The similarity matrix is based on the cosines of a time series of kernel-transformed Fourier based features designed with this domain in mind. Our method is applied to EDM streams. Its formulation incorporates long-term self similarity as a first class concept combined with DP and it is qualitatively assessed on a large corpus of long streams that have been hand labelled by a domain expert.
978-3-642-41142-7_24_Chapter.pdf (187.36 Ko) Télécharger le fichier
hal-01459615 , version 1 (07-02-2017)
Paternité
Tim Scarfe, Wouter M. Koolen, Yuri Kalnishkan. A Long-Range Self-similarity Approach to Segmenting DJ Mixed Music Streams. 9th Artificial Intelligence Applications and Innovations (AIAI), Sep 2013, Paphos, Greece. pp.235-244, ⟨10.1007/978-3-642-41142-7_24⟩. ⟨hal-01459615⟩
45 Consultations
135 Téléchargements
