Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : Recommender Systems have been applied in a large number of domains. However, current approaches rarely consider multiple criteria or the level of mobility and location of a user. In this paper, we introduce a novel algorithm to construct personalized multi-criteria Recommender Systems. Our algorithm incorporates the user’s current context, and techniques from the Multiple Criteria Decision Analysis field of study to model user preferences. The obtained preference model is used to assess the utility of each item, to then recommend the items with the highest utility. The criteria considered when creating preference models are the user location, mobility level and user profile. The latter is obtained considering the user requirements, and generalizing the user data from a large-scale demographic database. The evaluation of our algorithm shows that our system accurately identifies the demographic groups where a user may belong, and generates highly accurate recommendations that match his/her preference value scale.
https://hal.inria.fr/hal-01459641 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, February 7, 2017 - 1:06:08 PM Last modification on : Thursday, September 2, 2021 - 8:14:03 AM Long-term archiving on: : Monday, May 8, 2017 - 2:00:44 PM
Salvador Valencia Rodríguez, Herna Lydia Viktor. A Personalized Location Aware Multi-Criteria Recommender System Based on Context-Aware User Preference Models. 9th Artificial Intelligence Applications and Innovations (AIAI), Sep 2013, Paphos, Greece. pp.30-39, ⟨10.1007/978-3-642-41142-7_4⟩. ⟨hal-01459641⟩
